Hi there
I dont have a hand book and cant figure out how to adjust the trip computer. How do you reset the dist and fuel usage? How do you adjust the speed warning beep? If it starts to beep due to low fuel, can you reset that? Thanks for any help
Kev ![]() EL XR8 185kW |
EBII XR6
What model?
To reset dist and fuel usage etc just use the search button to select the desired selection, then just hold the reset button for a few seconds until it resets. If it has a speed warning I'm assuming its for EF/EL so I cant answer that for you. When it beeps due to low fuel just press the reset button and it will stop beeping.
DEVLXR
thanks Brad
Yes it is an EL. Thanks for the tips i will give it a try
