Old 25-02-2007, 10:54 AM   #61
BlackLS
Also a camber kit may be a good idea if you don't like the idea of replacing the rear tyres every 20,000
Old 25-02-2007, 06:25 PM   #62
orsest170
WRC Fanatic
orsest170's Avatar
You would only need a rear camber kit (front has camber adjustment already), and even then it’s not a necessity. The camber on my car was only slightly out (although it’s an XR5 and it has a different suspension set up to yours, so it’s probably not a good guide), but as long as you rotate your tyres regularly, you will still get good mileage.
You should be able to find a mechanic who will fit them for $150 or so, and after getting a wheel alignment, probably get away with it for around $500 - $550. I’d offer to help you myself, but I don’t have the required gear, and because I had someone else do most of the work, I wouldn’t be 100% confident of what I was doing anyway.
Panther Black XR5T
Pro Alloy Intercooler| Angel Eye Headlights (black)| Eibach Prokit Springs| K&N Gen II 57i CAI|
Dreamscience| InPro Black LED Tail lights| Black RS GT wheels| 14.007 @ 100.55 mph
orsest170 is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 07:17 PM   #63
Bucket
XR5 Pilot
Bucket's Avatar
Thanks for the offer I'll investigate!
Wish I'd saved the extra money to get the XR5...Insurance would hurt though!
'08 Ford Mondeo XR5 in Thunder
Bucket is offline   Reply With Quote Multi-Quote with this Post
Old 26-02-2007, 09:22 PM   #64
orsest170
WRC Fanatic
orsest170's Avatar
Yep, if you're under 25 then it would be very painful, but for those of us on the wrong side of 25, it's actually not too bad. I'm only paying $670 per year.
Panther Black XR5T
Old 27-02-2007, 01:37 AM   #65
BlackLS
Getting a xr5 turbo insured for an under 25 is only 2-4% more than a zetec, unless heaps of people that match your demographic in your area have crashed heaps of xr5turbos.
Old 27-02-2007, 10:26 AM   #66
orsest170
WRC Fanatic
orsest170's Avatar
I'm very surprised at that, I thought the combination of the words “turbo” and “under 25”, automatically got the insurers alarm bells ringing, and they hike the premiums up no end. Some of the younger guys on the XR5T forum are paying between $1500 and $2000 per year from memory, surely they wouldn’t pay anywhere near that for a Zetec?
Panther Black XR5T
Old 27-02-2007, 03:08 PM   #67
Bucket
XR5 Pilot
Bucket's Avatar
900 For me...
Old 03-03-2007, 02:31 AM   #68
REMZ
REMZ
So since youve put the superlows on. u think you can put 20's on it? without flaring out the guards? but how big can you go on the 2006 ls focus?
:king: THE KING IS HERE :king:
REMZ is offline   Reply With Quote Multi-Quote with this Post
Old 04-03-2007, 10:19 PM   #69
Zetec20
Zetec20's Avatar
short answer yes, front guards lipped is all...
: Don't yell, i'm probably hungover
Zetec20 is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 09:58 AM   #70
Gear
here's some info i used when changing the coils in my XR5, http://www.focushacks.com/index.php?modid=54
Very easy job to change the springs in the focus.
Jeff
Gear is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2007, 10:43 PM   #71
Penko13
Penko13's Avatar
Take your airbox off (remove the rubber pipe between the airbox and the tb) and there should be like a thick rubber band thingy on the rad support. Then just pull the airbox out.
You'll see the snorkle down there with the silencer in it, which is moulded into the second airbox
I didn't get rid of the pipe completely, I just dislodged it from its hole in the bottom of the airbox.
Theres 2 ways of getting rid of it, cutting it with a hacksaw and removing the whole second airbox. Cutting will make it hard to replace, Removing takes a lot of effort removing the wheel well guard and the corner under panel guard, and could lead to more frequent battery failures (this airbox supplies a bit of cool air to the battery box
Hey
i want to do the same thing you have done with your intake silencer, i have read what you did about 20 times but i'm still a bit lost. also does it make much of a difference in sound with the intake noise.
cheers
Penko13 is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2007, 12:36 PM   #72
BlackLS
First year of owning the LX was $3100. NRMA were the only people who would insure me.
When insurance was up for renewal in Nov last year, I changed to AAMI, $2100 a year with $2000 excess...
Old 28-03-2007, 01:01 AM   #73
jono26
No, its stardard.
Although I removed the intake silencer pipe and 2nd airbox so under load you get the deep intake noise.
how do you remove thouse?
jono26 is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2007, 01:08 AM   #74
jono26
have you got 20s on your?
Old 28-03-2007, 08:21 AM   #75
aston
Hi Guys
I have my Focus CL with the 17" Zetec Wheels. I want to get it lowered (slightly) as I think it sits too high on the wheels. I actually want it to look like factory height rather than 'looking' lowered. I know the Zetec sits around 10mm lower than the standard and I believe the XR5 is another 15 mm lower so I was hoping to lower it no more than 25mm but preferable around 15-20mm.
I have spoken to Pedders and there Sportsrider suspension lowers the car 35mm and I spoke to the distributors of the Eibach springs and they are lowered 30mm.
What would be my best option for lowering the car around 15-20mm?
Also if someone has a lowered Focus on the Factroy 17" could you post a side profile shot and let me know how much lower than the standard suspension it is?
aston is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2007, 09:47 AM   #76
melbzetec
Old enough to know better
melbzetec's Avatar
Might be worth finding out what a set of genuine XR5 springs will set you back
Old 28-03-2007, 10:25 AM   #77
Marshy79
Hey Aston.. go jump over to www.fordxr5turbo.com and post on the forum you might be looking for some XR5 springs.
A few people have changed to the eibachs so they might have some sitting in thier garages.
Marshy79 is offline   Reply With Quote Multi-Quote with this Post
Old 28-03-2007, 10:57 AM   #78
BlackLS
No, Zetec 17s
See post 26.
