Hi,
I have noticed that the inside edge of all four tyres have worn badly and need replacing. Is this a common thing? The tyres have only done 28,000 km. Hoich
2016 MD Mondeo Titanium Hatch |
Thats ok k's for me,but it does sound like a decent wheel alignment is needed.
just make sure you take it to a place that does camber and castor
as most small time tyre shops that do"alignments" only do toe adjustment
Flying high...
You may need to purchase a camber castor kit, especially if your car has be lowered, or hit a few gutters which changes your alignment...
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel, 3" mandrel intake, K&N pod in the box, Polished Rocker Cover. |
mezzo forte
Sounds like you've lowered without adjusting camber?
Hi guys,
Thanks for the tips. Car hasn't been lowered. Hoich
_Oo===oO_
If the alignment is done correctly as blackers10 has pointed out you shouldn't need a camber kit.
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
#8 | |||
They could not adjust front camber enough to stop excessive inside front tyre wear & Ford told me to take a hike Fitted a pedders camber caster kit and got a quality alignment same time & has been perfect to 73000 ks Make sure you get a print out of the alignment readings as they have the recomended settings on them Cheers Autocade |
Thanks for the tips Autocade.
I have booked my car in at pedders for Thursday. Hoich
