Old 14-02-2007, 03:00 PM   #1
20focus05
I wanna XR5
20focus05's Avatar
Default Turbo duratech!
What do you rekon?
http://www.focussport.com/turbocharger.htm
Don't know if it work with aussie focus, do they run same ecu. etc
20focus05 is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2007, 03:02 PM   #2
photn
AFF Post NAZI
photn's Avatar
if you got the doosh. go for it lol. should be good.
Old 14-02-2007, 04:37 PM   #3
Piotr
Non-Regular Member
Thats nothing, take a look at http://www.turbosmart.com.au/index.php?id=75
Twin Sequential turbo
Piotr is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2007, 04:58 PM   #4
melbzetec
Old enough to know better
melbzetec's Avatar
Can we get rid of the "H" in Duratech in the title? It drives me NUTS!
Old 14-02-2007, 06:49 PM   #5
Zetec20
Zetec20's Avatar
yummo, bit pricey though...
: Don't yell, i'm probably hungover
Zetec20 is offline   Reply With Quote Multi-Quote with this Post
Old 14-02-2007, 09:17 PM   #6
eXtremist
2007 Ford Focus Zetec
eXtremist's Avatar
Apparently, this turbo kit was discussed on the FordXR5Turbo forums, and BlackLS said that the turbo/exhaust would hit the steering rack.
eXtremist is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2007, 05:43 PM   #7
BlackLS
Also ECU flash with preloaded firmware would be useless
Old 15-02-2007, 09:59 PM   #8
20focus05
I wanna XR5
20focus05's Avatar
you guys are an absolute wealth of info, melb thats a silent "H" lol
Old 16-02-2007, 12:54 AM   #9
Piotr
Non-Regular Member
Only they don't come with preloaded firmware. "Included in the kit price is FREE dyno tuning support". Its comes with the Flash tuner so you can change tune easy
Old 16-02-2007, 07:09 AM   #10
melbzetec
melbzetec's Avatar
Silent H? That's OK then!!
Old 16-02-2007, 10:09 AM   #11
BlackLS
I highly doubt that the US duratec has the same ECU mapping as ours. But anyways.
From the site:
"FocusSport/SCT XCalibrator 2 ECU flasher WITH Stage 1 programming"
This means it comes with estimated tunes on it for the turbo installation.
Free dyno tuning support means that your XCal dyno tuner (that you pay for) can call up Focus Sport and get some pointers on some parameters that could be modified to extract more power from the base turbo tune that FocusSport supplied.
Old 16-02-2007, 10:17 AM   #12
BlackLS
http://www.fordxr5turbo.com/forum/in...p?topic=1302.0
If you wanted tunes for turbo LS, talk with DreamScience in the UK like this guy in Taiwan
http://sctflash.com/forum/showthread.php?t=7918
If I were in the position where there was a turbo hanging off the engine, it would be straight to CAPA
