Old 14-04-2005, 10:26 PM   #1
trueblue
01 Falcon Ute
Default Ford factories
Hey, i am just trying to find some information out
where are all the Ford factories without australia and what are they there for basically
cheers...
AUII FALCON UTE 2001
WTD mags to suit AU Falcon ute, AU XR rims or BA 18" xr rims. PM ME
trueblue is offline   Reply With Quote Multi-Quote with this Post
Old 14-04-2005, 10:29 PM   #2
LSD
They have something in Broadmeadows I know that much. Not sure if it's a car factory, an engine factory (or more accurately: an engine assembly plant) or just an office though :(
Old 14-04-2005, 10:33 PM   #3
LUXO_8
windsor user
engine, stamping and casting is in geelong, assembly is in melbourne,
prooving ground is in lara.
Old 14-04-2005, 11:09 PM   #4
trueblue
01 Falcon Ute
i also hear theres somthing in brisbane?
Old 15-04-2005, 09:42 AM   #5
wulos
Forum Director
wulos's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind-the-scenes effort. Technical Contributor: For members who share their technical expertise. - Issue reason: For his advice, tips/tricks in the Art and Photography section of the Forum.
Listings of plants in Australia
Broadmeadows - Assembly Plant
Geelong for Aluminium & Iron Casting, Geelong Stamping, & Geelong Engine Plants.
No listings for other Ford production plants in Aus
Need to remember FPV is just over the road from Broadmeadows Assembly - consisting of V8 engine plant(Boss production - not sure if 220 is also assembled there though, or whether the 220's are assembled in Geelong), & FPV Body assembly plant.
wulos is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2005, 09:47 AM   #6
b2tf
not here much anymore
b2tf's Avatar
Aren the 220's pretty much complete when they come into Australia? Or am i way off...:
2024 F150 XLT
Old 15-04-2005, 09:55 AM   #7
wulos
Forum Director
wulos's Avatar
EaGHIA - I know you're aware of the following - but others may not be....
http://www.ford.com.au/inside_ford/h...e/Heritage.asp
/me thought a bit of CHEST BEATING was in order & decided to highlight THIS little gem from off that link
"Falcon, Fairlane and LTD are the only current volume-built true Australian cars, which are wholly styled in Australia from original sketchpad concept and then engineered and manufactured here"
Old 15-04-2005, 10:05 AM   #8
trueblue
01 Falcon Ute
Yes. but when i told you this
""Falcon, Fairlane and LTD are the only current volume-built true Australian cars, which are wholly styled in Australia from original sketchpad concept and then engineered and manufactured here""
you said there was a fairlane factory in brisbane
Old 15-04-2005, 10:18 AM   #9
Trevor 57
Trevor 57's Avatar
Ford Trucks used to be put together in Brisbane, but Ford Trucks are no more, they are now owned by Mercedes Benz and are released re-badged as Sterling.
Trevor 57 is offline   Reply With Quote Multi-Quote with this Post
Old 15-04-2005, 10:21 AM   #10
Trevor 57
Trevor 57's Avatar
Just to clarify the points, the G220 is a Fairlane, and they are wholy Aussie designed and built.
Old 15-04-2005, 10:21 AM   #11
trueblue
01 Falcon Ute
/me thought that this link is a bit out of date?
Old 15-04-2005, 10:24 AM   #12
b2tf
b2tf's Avatar
Sorry,what i meant was the 220kW Engine, not the G220. My apologies for not being clear enough.
2024 F150 XLT
Old 15-04-2005, 01:19 PM   #13
trueblue
01 Falcon Ute
1925 Ford Motor Company of Australia formed on March 31. Production of Model T begins July 1 in leased premises in Geelong. Construction of assembly plants in Geelong, Brisbane, Fremantle and Adelaide commenced.
1930 Fremantle (WA) assembly plant opened in March.
1936 Homebush (Sydney) assembly plant opened March 17
1959 Broadmeadows Car Assembly Plant opened in August.
1966 - $2 million extension to Brisbane Plant.
1998 - Brisbane Assembly Plant closed.
1987 - Fremantle Rectification Plant closed.
1994 - Homebush Assembly Plant closed
ummm
when did the adelaide manufaturing plant close?
cheers
