Old 10-02-2007, 11:40 AM   #1
Heretic
Default AU1 Fairmont light switch help please
Guys, i have a 99 Au Fairmont that has developed a electrical problem. the dash lights are non functioning as well as the front and rear park lights. Main lights high/low beam work fine. Also the lights off delay switch has stopped working. When the ignition is switched off the "lights on" warning iluminates and gives me the warning sound. (even though they arent on, wots with that Henry)
All fuses ok, the only common part with all the symptoms is the Fairmont style light switch with the dash brightness level and lights off delay switch.
Has anyone else had this problem, common Fairmont issue?, is it the switch shorting and just a case of replacing the switch. Cars done 142,000 lazy k's only.
Any help you guys can give me greatly appreciated - cheers, Heretic
Heretic is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2007, 11:48 AM   #2
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Change the fuses anyway... check your tail light & indicator bulbs, check your trailer plug (if you have one - sometimes people will put a paper clip in there to screw you around)...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
