Old 05-02-2007, 01:26 PM   #1
482bze
eb xr666
Default help i think im gettin ripped off please help
hey guys i need some help i went to the wrecker to get the parts to convert to mpfi and there tryin to charge me $420 bucks and from what iv read in the forums i should be payn $150 to $250 and every wrecker i go to adds another part the original list is
manifold, fuel rail, injectors, tps isc and air temp sensors, air con bracket and the two bolts for it, mpfi manifold loom, brake booster hose breather hose and map sensor hose
the wreckers added
mpfi e.c.u., distributer, accel cable, air box and duct, fuel pump,ecu loom
so what i need to know is what do i actually need
my car as it sits now is 1990, cfi, 4sd auto and also
beside it is a 1989 5spd man (complete car )which will go in with the mpfi convert
cheers i really need the help thanxs :eclipsee_
482bze is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 02:06 PM   #2
EFFalcon
Last warning
EFFalcon's Avatar
everyting you've listed is required, saying that, wrecker prices depend on where you go, the cheaper prices are most liekly those from a self serve wrecker where you get all the bits you need yourself, ends up cheaper but more work.
deffinately need the parts the wreckers are including.
also worth lookin at getting the heater pipes from the MPFI car too.
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 05-02-2007, 02:09 PM   #3
[Tonko]
What's green is gold
[Tonko]'s Avatar
i got a quote for $800 for all of the bits and pieces, more than my car was worth....
EF XR8 - Koni's - Cam and Headwork -3.9s - Ex VIC TMU -
1982 Nissan Patrol - 460 ci Big Block soon - Semi Gloss Black - Dark Tint - 4x 6" Infinity Kappa Perfect Splits - 5" Kappa 2 ways - Kappa 6x9's - 2x12" Kappa perfect subs - 2x4 Channel and 2x Mono Kappa amps-
[Tonko] is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 02:24 PM   #4
TUFED6
TUFED6's Avatar
For that kind of money you're probably better off buying a whole MPFI EA to raid for parts.
Most wreckers will tear you a new one if you don't know what things are worth. Eg, a whole EA from the auctions is worth around $100.
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 04:22 PM   #5
DEVL-XR
EBII XR6
DEVL-XR's Avatar
+1 for buying a donor car, then you can sell the rest of it when you get all the parts you need.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 05:35 PM   #6
DNKPWR
DNKPWR's Avatar
Is it cheaper and better to just get a new engine like an el or au they are about $500 bucks from the wreckers!!
BA XR6 TURBO - SILVER & 1970 Mustang Coupe
DNKPWR is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2007, 09:50 PM   #7
482bze
eb xr666
i ended up gettin all the parts for 250 cheers and thanx
Old 06-02-2007, 09:31 AM   #8
steven95falc
Damn i just bought a series 2 eb i am wrecking would of done them for real cheap.
steven95falc is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2007, 10:42 AM   #9
482bze
eb xr666
dood im in qld
