Old 01-01-2007, 11:47 PM   #31
TruBlu351
3 Pedals R Better Than 2
TruBlu351's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: Has given endless help in the cleveland section over the years. Knows his stuff and happily tests on the track and gives no fuss results.
Looks like it will weigh a bit too........and with only a 5 litre? It's just another pimp mobile.
Interceptor? Mad Max wouldn't be happy with that.
XE Falcon - Under Construction
434 E85 Lawn Dart underway
TruBlu351 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2007, 11:56 PM   #32
LUXO_8
windsor user
some specs found on the 5.0 "cammer"
The "Five Liter" Is Back
The foundation for the Mustang GT-R's race-prepared 440-horsepower engine is the new 5.0-liter "Cammer" crate engine from Ford Racing Performance Parts. The engine is rooted in the MOD 4.6-liter four-valve V-8 engine family. However, the motor's flanged cylinder liners help provide 94mm (instead of 90.2mm) cylinder bores, creating a full 5.0 liters of piston displacement.
And while the motor employs the SVT Mustang Cobra’s forged crankshaft with six-bolt mains and Manley "H-Beam" connecting rods for superior strength, the high-strength Ford Racing block features design reinforcements and a revised material for added strength and high-output durability. The block is specially reinforced in the crankcase web areas for high torque loads.
Other key differences include forged pistons, an 11.0:1 compression ratio, ported heads, higher-lift cams and beehive-shaped valve springs. The crate engine also features higher-flow fuel injectors and a magnesium, variable-geometry intake manifold.
The 5.0-liter "Cammer" engine comes with a custom oil pan and features custom-fabricated Tri-Y headers and crossover.
Engine – Ford Racing 5.0L "Cammer" V8
Configuration................V-8, aluminum block, aluminum four-valve cylinder heads, forged aluminum pistons
Bore x Stroke................94 mm bore x 90.0 mm stroke
Displacement.................5.0 liters (302 cu in/4995 cc)
Compression..................11.0:1
Power..........................440hp (328kw) @ 7000 rpm
Torque.........................400 lb-ft (542nm)@ 5500 rpm
Redline.........................7,000 rpm
Valvetrain.....................Double overhead cams, four valves per cylinder
Int. valves....................Two per cylinder, 38 mm
Exh. valves...................Two per cylinder, 32 mm
Throttle body................Twin 57 mm
as for weather this car gets this exact version who knows.... but those specs have all the right numbers to me
Old 01-01-2007, 11:57 PM   #33
uranium_death
uranium_death's Avatar
I don't like it.
American cars lack the sexy shapes that Aussie cars have...they're still boxy and have hideous lights that would fit on a car from the 1980s.
No. I'll wait for the Orion to be released, then we'll watch the average American laundromat profits triple due to the extra amount of underpants that'll need to be washed.
uranium_death is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 08:53 AM   #34
BlueRaven
Dual O2 sensors
BlueRaven's Avatar
Very heavy handed design. American designs typically have an over-the-top quality to them that seems bizarre to the rest of the world, especially for us with our cars being really quite conservative in comparison.
I look at that car and can see what they were trying to achieve but its way too loud in design.
Black 1990 300zx Twin Turbo 5 Speed Manual :
Blue 2004 Mini Cooper S 6 Speed Manual - Yes, thank you Amanda. I realise now that you updated my signature to include your car. :
BlueRaven is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 09:51 AM   #35
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Chrysler 300C meets GMC Surburban...
No wonder Ford US is in trouble.... they can't design for s***. They should just give up trying to build in the large car market, and just import the Falcons...
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 10:02 AM   #36
OLDFORDNUT
OLDFORDNUT's Avatar
looks ungainly,huge body and little sports car roof.and front looks like it should be on back
Hervey Bay QLD
Great trades recently- GILMORE
BOSSYONBIKE
OLDFORDNUT is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 10:22 AM   #37
parawolf
beep beep
What an ugly car... Can't Ford look towards the Italian concept cars for true vision and design influence rather than taking freight train influences?
http://www.theage.com.au/articles/20...html?from=top5
Nothing to see here, move along, move along...
parawolf is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 10:45 AM   #38
Falc'man
You dig, we stick!
Falc'man's Avatar
Poor effort, they can do better I'm sure.
Falc'man is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 11:18 AM   #39
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
"This concept celebrates the best of American muscle, showing customers what 'modern muscle' is all about," Peter Horbury, Ford's executive director of design for The Americas, said in a statement.
Bwahahahaha - modern muscle my a***.....
Old 02-01-2007, 02:15 PM   #40
Chuggwald
I think it looks great, best Ford concept in ages. Bonnet has good helpings of MX-5 styling, side is great, back bumper needs to be fixed a bit, and maybe grille changed to get rid of Chev simularities, but the presence of it is fantastic!
Chuggwald is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 03:13 PM   #41
majin_andrew
Another vote for "Looks good".
majin_andrew is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 04:47 PM   #42
GlennBA
GlennBA's Avatar
Thats tough as nails! I don't like the grill though.
GlennBA is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 06:00 PM   #43
Jayden
Graphic Artist
Jayden's Avatar
Pimp mobile sounds about right. no wonder their sales are suffering.
For crimes against aesthetics in automotive culture, I sentence you to a life of commodore.
Jayden is offline   Reply With Quote Multi-Quote with this Post
Old 02-01-2007, 06:33 PM   #44
The Stylist
Automotive Designer
The Stylist's Avatar
What???, the car is not even in production! Ford's U.S problems stem from poor operational management, and investment in the right product mix. They haven't had a decent (or updated) large car for years.
A lot of people on this side of the Pacific don't seem to realise that tastes from continent to continent differ. America is not Australia and vice versa, their cars come from a typically bold heritage which is why the Interceptor concept is more likely to be warmly recieved over there than down under.
The Stylist is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2007, 01:08 AM   #45
Jayden
Graphic Artist
Jayden's Avatar
^I could like it, but it looks too bulky and impractical, even more so than the 300c. And I dont think its the right product still, but that depends on what area they are trying to fill with this? no seriously I have no idea. The GMC/ Chrysler Defectionist market?
Old 03-01-2007, 03:05 AM   #46
FalconXV
FalconXV's Avatar
Initially I didn't like it; but I don't think it copies the 300C; it is far simpler- The rear end is reminiscent of the 427 Concept; but the front is striking yet amazingly simple. It looks like something that would fit in the Ford US line-up. They just want a slice of the 300C pie; but they should have jumped on much sooner, because the clock is ticking.
As for the engine- that looks like it could well work in a Falcon down here- Much better specific power, lighter (alloy block), higher redline than TOSS290- even though the performance batton has been passed on to the turbo 6, we still need a competent V8!
FalconXV is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2007, 09:52 AM   #47
JPFS1
JPFS1's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community.
gimme the engine, ditch the rest.
JPFS1 is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2007, 01:32 PM   #48
dallasv8
5.8 litres of fun
dallasv8's Avatar
definitely doesn't do it for me.ill pass on that one.
2003 RTV
2015 Ranger XLS mk2
dallasv8 is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2007, 02:07 AM   #49
Jayden
Graphic Artist
Jayden's Avatar
After a longer harder look at it.... I decided I like the colour, it would be good for any Ford too.
the design feel of the car hasnt grown on me, seems to sit a bit high and nothing about the rear end is appealing at all. But, I think it could be made quite awsome with some changes at the drawing board. mainly more old school muscle influence and less QEII.
Im almost inclined to attack it with PS myself if I wasnt so busy cause I am seeing potential now.
Old 05-01-2007, 02:14 AM   #50
Tles
I really like it!
It would need some Aerobics OZStyle to be a good base for Fairlane though.
Or even for Crown Victoria....
The Saudis just voted the Chev Caprice/Statesman the best Luxury car over the Euro snob mobiles including Audi A6 and even Japs like the Lexus ES350. They reckon the Holdens have better ride and handling, durability and even build quality. Wait till they get some Orion Falcons and Fairlanes to try!
Tles is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2007, 09:08 AM   #51
Mechan1k
Mechan1k's Avatar
New F-truck front ... with Bentley coupe-style taillights.
300C style chassis.
Looks kinda like a bitza car.
And as others have said ... needs a larger motor.
Old 05-01-2007, 09:29 AM   #52
stockel
stockel's Avatar
Originally Posted by xafalcongs
Sorry but the grill and headlights look like they pulled then out of a 10 yr old Chevy truck. Same style light stack, same center chrome bar running through the grill. In fact, that chrome center bar is a Chevy design theme that they've used for years and is very distinguished in the current line of US cars and trucks.
lol thats exactly what I was thinking and as said the 300C influence is obvious. Honestly does nothing for me.
stockel is offline   Reply With Quote Multi-Quote with this Post
Old 05-01-2007, 02:10 PM   #53
Dauphin
Irregular member
Dauphin's Avatar
I like it but it needs some work. Ford certainly have missed the boat after the 300C came out.
Old 10-01-2007, 11:28 AM   #54
Bossxr8
Peter Car
Bossxr8's Avatar
The cowl induction shaker hood is pretty awesome.
As for looking like a 300C, is that really a bad thing as they are selling like hotcakes in the US.
Old 10-01-2007, 05:24 PM   #55
MrSparkle
An Old Boss™©
Contributing Member
MrSparkle's Avatar
Originally Posted by The Stylist
Some more info from Autoblog,
Ford Interceptor Concept
Keeping Mustang momentum accelerating
The Ford Interceptor concept – based on a stretched Mustang platform –
Suspension
Front....................... Double wishbone-independent
Rear.........................3-Link Design with Panhard Rod (Oh dear, no IRS)
... and there we have it folks, yet another "space age" 21st century technical masterpiece by the engineering intellects at Ford. Perhaps by 2020 we will see the introduction of IRS into the concept car range, followed by a prolonged marketing campaign and a production implementation in time for the all-new 2047 Mustang.
Where did I go? What was I doing there?™©
MrSparkle is offline   Reply With Quote Multi-Quote with this Post
