[ 5L ]
i want to lower my car around an inch to an inch and a half in the rear. i think that the front is fine. what springs will do the job, and are the springs the same as e-series springs, where xr springs are fairly close to king spring lows.
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
Spin 'em Habib !
is it the EB or the XR8 You want to lower ,
Super Lows would look Good , would shake it down a bit , but Going by Whoosh's , It looks fine in the Narooma if you just leave it stock ![]()
AU2PWR |
[ 5L ]
not eb i want to lower that thing is slammed already,
plus i posted in au section so that means xr8 lol, i dont really want superlows, they gave my eb a rough ride, and i dont want that in the au. just want to lower the rear a bit more, maybe ill just chuck some bags of cement in the boot.
Spin 'em Habib !
lol
Just do my trick , carry your drag tyres x2 plus your spare wherever you go ![]()
AU2PWR |
king spring lows would bring it down a bit, but bugger all of a diff in an xr, for an inch- an inch and a half you'd probably want sl's
#6 | |||
Spin 'em Habib !
AU2PWR |
[ 5L ]
i just thought that superlows would make it heaps low.
Spin 'em Habib !
Ultra Lows Would , SuperLows , Meh , Would leave it at a Nice Height
AU2PWR |
#9 | |||
![]() Join Date: Jan 2005
As a guide, the road to wheelarch measurement on your car should be around 660 to 670 at the moment, with SLs, this should drop to around 640 to 650. The front should already be around 660/665 as well. I believe that by keeping the front XR height, and putting SLs in the rear, the rear will sit lower than the front, a la VL commodes. However, if you go SL front and SSL rear, the car should sit flat. Not that it matters to you, but I have SL front, and XR rear, because with a full gas (LPG) tank, the rear sits around 10mm lower than whatever springs are in it, so SLs were bottoming out all the time.
if you want superlows but don't want to lose the ride quality you can weld a spacer on the shock tower to give you full travel. i have ultra lows and have made up spacers. to look at its slammed but when you take someone for a drive they can't belive the ride quality and only takes 1/2 hour to do.
