Old 20-12-2006, 11:23 PM   #1
Cooper69S
Cooper69S's Avatar
Default camber castor kits
gday all
realised yesterday that i need a kit pretty badly - obvious camber on both front wheels and worn smooth both inside edges in 17000km. had quotes to install a kit $395 - $415 which isn't as cheap as when i had it done on the EF but that was in Perth and theres more choice of fitters there than in Bunbury.
is fitting a kit a DIY job or are there special tools needed? would it be a lot cheaper to buy and fit the parts and then just pay for an alignment?
Geoff
Cooper69S is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2006, 11:35 PM   #2
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
Yeah Buy the Parts , Get It Aligned , Not sure on the Tools Side of things
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2006, 11:48 PM   #3
JoesAu
JoesAu's Avatar
i have the kmac ratchet type one. bought it for 320 installed by me and my dad, bit tricky to get the tools where u need em in certain spots, no special tools needed either. i'd say get someone else to do it save the headaches.
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2006, 11:57 PM   #4
futura97
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Writing tech article(s)
yeah its pretty easy, just jack the car up and working on the ds undo the 4 15mm nuts holding the upper arm in. On the PS its easiest to get the nuts from underneath. A ratchet spanner makes life real easy!
after undoing these, arms will just pull back, and swing to the side. Replace bushes (if needed) and then bolt in the new kit. Done!
futura97 is offline   Reply With Quote Multi-Quote with this Post
Old 21-12-2006, 11:28 AM   #5
Cooper69S
Cooper69S's Avatar
ordered a kit from Wilkinson suspension in bayswater - only $75 each side - huge saving thanks guys just gotta go buy some ratchet spanners will still be way in front and i've always wanted some of those spanners anyway...
Old 21-12-2006, 07:57 PM   #6
futura97
good stuff.... just make sure you get some form of warranty, or a decent set. We bought a set and the first nut we went to loosen broke the ratchet!
Old 21-12-2006, 07:59 PM   #7
Cooper69S
Cooper69S's Avatar
was probably going to get kinchrome - they're reasonable and lifetime warranty i think...
Old 21-12-2006, 08:21 PM   #8
blackers10
blackers10's Avatar
superworks gold is made by stanley that also make sidchrome so ill probably get those
On The Street Feature Winner Performance Ford Mag
See my car at:-www.aufalcon.com/blackers10
blackers10 is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 01:50 AM   #9
GK
Walking with God
GK's Avatar
For what it's worth, I was told today at the local Tyrepower today that these units often slip, thus losing their setting. The guy said to go for the shim type units. Longer to set, but set will remain true.
Also told that the factory settings for Falcons were great for turn in, but really dodgy for tyre longevity.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 22-12-2006, 01:56 AM   #10
chief
FTF Club Moderator
chief's Avatar
This AU area must be full of nocternals lol. Lets see JC, B2TF, GK, Chief, blackers10
Sorry no relation to the thread, thought I just point that out.
Albert Einstein:
Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom.
(It is more difficult to alter a preconception than split an atom)
Falcon Tickford FPV (FTF) Car Club of NSW
Fords in the Park 2010
I use and recommend Stingray Car Security.
http://www.stingraycar.com.au/
chief is offline   Reply With Quote Multi-Quote with this Post
Old 22-12-2006, 02:24 AM   #11
blackers10
blackers10's Avatar
definatly chief we are nocturnal LOL.. i work 2pm-midnight so this is afternoon to me
you can order in nolathane and or fulcrum gear thru your local supercheap store!
just see the spare parts counter
and its helpful to bring in the parts numbers with you if you can otherwise it makes it take 10x longer for the person to find the prices for the parts you need (especially if you get an un trained moron that supercheap is finally realising they employed alot of and its a BIG black spot on their record that they are FINALLY fixing!!)
Old 22-12-2006, 04:33 PM   #12
GK
Walking with God
GK's Avatar
Been falling asleep on the couch whilst pretending to watch TV LOL!
Waking up around 12-1ish, heading to bed when I hear that oh so familiar and welcoming whirr of the computer CPU cooling fan! Hmmmm the PC is still on, I think I'll check out the forum! LOL!
And you know the rest, an hour later.......!
GK
Now gone!
On LPG
