27-11-2006, 05:03 PM | #1 | ||
Hey all, I have had my car lowered on Standard 17inch rims for over a year now and i have had the tyres Dunlop 3000A for nearly 2 years now and all my tyres are nearly worn. My Front drivers tyre is totally bold on the inside while the other side there is some tread left! I spoke to the tyre people and they said you need a camber kit. Spoke to a few mechanics and they said that you dont need one, they are only 17inch!!!!
I dont drive all that hard or do burn outs so what can i do to avoide this happening in the future and any suggestions why this has happened would be greatly appreciated!!! Thanks a bunch!! (the CAR is a AU XR6 02 SII) |
27-11-2006, 05:08 PM | #2 | ||
Just slidin'
Im on SL's and 17's and was told I had to have camber kits. I think its better to be safe then sorry anyway.
MD Mondeo - For the family
27-11-2006, 05:09 PM | #3 | ||
tyre size has no bearing on if you need a camber kit or not.. and it sounds like you do mate.
27-11-2006, 05:24 PM | #4 | ||
Adapt or perish...
Sounds like you have the same problem I did.
I told my mech about putting a camber kit in and he said I don't need it, and adjusted my toe in about a degree and haven't had any uneven tyre wear on the front, but I have a real floating sensation on the highway now.
Carless
27-11-2006, 05:26 PM | #5 | |||
AU DIE HARD
The caster camber is different on all cars I have had 4 AUs up the drive .we lowered 1 had the front end re alignment no problems the next needed the caster camber kit .. it just the luck of the draw . just take it to a reliable front end place & they will tell you what it needs
27-11-2006, 05:41 PM | #6 | ||
Audi S3
how many kilometres have you done on the tires?
27-11-2006, 05:52 PM | #7 | |||
Its Resonating!
27-11-2006, 05:59 PM | #8 | |||
_Oo===oO_
COURAGE - ENDURANCE - MATESHIP - SACRIFICE
28-11-2006, 08:47 AM | #9 | ||
ok the tyres have done about 25 XXX. And i havent really roated them like i should. Will a camber kit affect handling?
28-11-2006, 08:51 PM | #10 | |||
29-11-2006, 08:53 AM | #11 | ||
yeah, a wheel alignment has been done after lowering. I just might need a camber kit. With a camber kit does that mean i will never need a wheel alignment?
29-11-2006, 09:55 AM | #12 | ||
lpg = big boom!
camber kit just chages the angle...
if you hit a nice pot hole you are still going to need a wheel alignment, lol
BF Futura Dedicated E-GAS w/Ghia bling Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM |
29-11-2006, 10:49 AM | #13 | ||
Has anyone had any positive comments regarding a camber kit??
29-11-2006, 11:10 AM | #14 | ||
I got one after i lowered my car for the 2nd time. definitely worth the money. gives more adjustment for lowered cars.
i had a awesome looking camber, but would have killed my tyres in no time.
Powered by Rollin Motorsport Turbo Barra ED 4L
29-11-2006, 08:30 PM | #15 | |||
29-11-2006, 11:53 PM | #16 | |||
See http://www.motovicity.com/Manufac/SPC/index.htm
regards Blue |
30-11-2006, 09:38 AM | #17 | |||
Approached Ford as a warranty claim who said it was within spec & politely told me to go away I tried the toe in method for a while but the car felt skittish at high speed Approx 40000 ks ago I fitted a Pedders kit which solved my negative camber problem Another option is to fit the upper control arm mounting brackets from the T series which allow for shimming camber I chose the Pedders kit because it also allows caster adjustment plus it was a cheaper easier option for me at the time Cheers Autocade |
