14-11-2006, 10:29 PM | #1 | ||
hey boys sounds like every1's 220 eating poo at moment :
Mine started running rough on sunday..I carried out the normal tests and came to the conclusion it was a mechanical failure..I pulled the rocker cover off the left bank tonite and found i have a broken or weak valve spring on no 8 exhaust valve..Obviously this is a common fault Im planning on just replcaing that one by having air injected through spark plug hole to keep valve up and removing and replacing with valve spring tool.. My questions are wot is the availabilty on these do most dealers stock them? Are they off a diferent strength to standard? And i found mine has Yellaterra rockers are these factory? cheers |
14-11-2006, 11:41 PM | #2 | ||
yella terra rockers are not not standard.
you can purchase the spark plug air fitting from coventry's and you could also get the above head spring compresser from coventry's/repco.. its pretty easy to do mate. u dont have a problem. just dont drop the collets when u take them off
01 AUII XLS Regency Red Ute 4.0L Egas Auto Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam, 1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD. Thanks to: EvilChief and SJW Performance |
15-11-2006, 12:31 AM | #3 | ||
Back on the road
YT rockers are standard on the 220kw XR8 engines.
The spark plug fitting will be less than $10, and the "on head" valve spring compressor about $30...its pretty easy to change using this method. I would question the value of only changing a single spring though..? How did you come to the conclusion the spring on #8 exh is "broken or weak"..?
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
15-11-2006, 01:58 AM | #4 | ||
Not good Mr T, sounds like a few 220's are falling over atm, drive one myself so fingers crossed.
As XR8Ute has pointed out YT's are factory standard on these ones. |
15-11-2006, 09:16 PM | #5 | |||
Im only replacing one as am unsure of which way i want to go i might hottie the motor up at a later stage as i am looking into buying a new project at the moment....Am waiting on the new spring genuine from ford at the moment (ordered today) 20 bucks, ex east |
15-11-2006, 09:23 PM | #6 | |||
15-11-2006, 09:33 PM | #7 | ||
sorry,. i didn't realise 220's came with YT rockers
15-11-2006, 09:37 PM | #8 | |||
Back to Le Frenchy
Hope it all goes well, you got lucky. What is it with no. 8 cyl lately?
15-11-2006, 11:27 PM | #9 | |||
Something about these 220's especially manuals that us owners probably agree on, they are like a cranky child, moody with bad manners but utterly loveable. Now I feel like heading out to the garage and giving mine a hug : |
16-11-2006, 08:28 AM | #10 | |||
With da Warlords
You don't have to be faster than the bear, you just have to be faster than the slowest guy running from the bear. For Sale: Parachute. Only used once, never opened, small stain. Windsor Warlords AU III XR-8220 300+ rwhp of Manual fun XR50T Ute - 300rwkw (give or take depending on the day)
22-11-2006, 12:23 AM | #11 | ||
Just like to note that shes all fixed and purring like a kitten again.
Quite an easy job in the end for such an integral part of the motor. |
22-11-2006, 07:54 PM | #12 | ||
did u fix it using the spark plug adaption and over head valve compresser?
22-11-2006, 10:30 PM | #13 | ||
yes it only too around 2 hours total from start to finish (driving in driving out) thats including working in the dark and being distracted by the missus..My sheds not very well light.
23-11-2006, 07:36 PM | #14 | ||
good for you mate. well done
