Old 18-11-2006, 09:27 PM   #1
needaXYGT
AU II XR8
needaXYGT's Avatar
Default AU suspension problem
the car drives fine, but everytime the front left hand wheel goes over a ditch it makes a knocking sound. it was taken to a shop where they tested the supension, but they couldnt find anything. its deffiently there though.
any ideas?
needaXYGT is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2006, 09:59 PM   #2
AK
AK's Avatar
Mine used to make a knock in the front and my mechanic changed the D-Bushes and its gone, dont know if it may be them?
Lightning Strike 09 G6E TURBO Shockworks Coilovers - Inovit Speedys - Streetfighter Intake
AK is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 01:53 AM   #3
JC
JC's Avatar
Yep mine too. Same problem, same fix. Swaybar D bushes would be my guess. Around $20 to fix, and an easy DIY.
Ford Performance Club ACT
Old 19-11-2006, 10:31 AM   #4
GK
Walking with God
GK's Avatar
Can you post us a pic of these JC? I think these are the ones giving me the squeaks. I spray some lube on them from time to time to make it quiet. Keeps coming back though.
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 19-11-2006, 11:58 AM   #5
needaXYGT
AU II XR8
needaXYGT's Avatar
ok thanks.
Old 19-11-2006, 01:09 PM   #6
needaXYGT
AU II XR8
needaXYGT's Avatar
is this another common problem with the AU, cause i also get the squeaks when its been sitting over night in the cold wether (5deg average)
Old 19-11-2006, 04:57 PM   #7
JC
JC's Avatar
GK
Coming right up. You really should take them out and grease them - it's the only way to shut them up properly.
Old 19-11-2006, 05:50 PM   #8
GK
Walking with God
GK's Avatar
Do these have a split in them JC? If they don't then how do you get them on?
I sprayed them yesterday with motorbike chain lube, much better than the thinner WD40 I used last time!
Hey my 2000th post, cool!
Cheers,
GK
Now gone!
On LPG
Old 19-11-2006, 05:55 PM   #9
JC
JC's Avatar
Cheers,
GK
Yep they have a split - pic added to previous post. Just replace them with nolathane ones (around $20) - I think Forte sway bar is 24mm and XR is 28.
Old 19-11-2006, 06:13 PM   #10
NeishaXR8_347
SS Grunt
NeishaXR8_347's Avatar
AU2 has the 24mm bar.
The Beast has gone to a new home
Morpheous VE SS 6LTR 6speed Manual in its place, Leather, Lowered, 20's, Ramjet OTR and Dual 3inch, 280RWKW
I will also enter any part of the Forum I wish to enter. :
NeishaXR8_347 is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 07:31 PM   #11
GK
Walking with God
GK's Avatar
Cheers, that's what I thought they were, but the Max Ellery manual didn't have them shown, everything else though! LOL!
I appreciate the pic.
Now, my SR would have the 24mm bar right? Funny thing, these were replaced by Pedders in January, but I wonder if I damaged them a bit when I changed over the springs. I was concerned about the sway bar. Remember that conversation JC?
I wonder if I wore the bushes a bit, they are after all the red hard plastic items, not rubber. Should I replace them you think, or just take them out and give them a good greasing up?
Two 13mm bolts or such from memory.
GK
Now gone!
On LPG
Old 19-11-2006, 08:12 PM   #12
NeishaXR8_347
SS Grunt
If they were replaced not long ago i would just grease them up, there is no reason they would be worn so quick unless they didnt grease them properly to begin with. But you will be able to tell when you pull them out if its just a grease or replacement needed.
Shaun
Old 19-11-2006, 08:43 PM   #13
AUXRVIII
I think it may be the upper ball joint, you wont get any freeplay, it will be dry, Ford dealers have a special tool for lubing the upper ball joint.
AUXRVIII is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 10:18 PM   #14
JC
JC's Avatar
Shaun
I agree - pull them out and grease them and see how they go. And yes, I remember the squeaky conversation, GK.
Old 19-11-2006, 10:39 PM   #15
GK
Walking with God
GK's Avatar
Shaun
Cheers JC and Shaun,
I'll pull them out and grease them up. Standard grease I assume? I have some Penrite grease (high boiling point) in the shed, I suppose that'd do.
GK
Now gone!
On LPG
Old 19-11-2006, 10:48 PM   #16
JC
JC's Avatar
GK
That should be OK. I use Castrol general purpose grease (red lid), and it works fine for most things. I also have a special one for wheel bearings (high temp, I think).
Old 19-11-2006, 10:58 PM   #17
crossingover
crossingover's Avatar
guys when doing upper and lower balljoints i usually get a needle and inject the lube in you can get large syringes from chemist for around 6 dollars my backyard mechanic mates trick
DUMPED AU
crossingover is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 11:06 PM   #18
GK
Walking with God
GK's Avatar
Darn good idea! I'll give that a go too!
Cheers,
GK
Now gone!
On LPG
Old 19-11-2006, 11:31 PM   #19
peterban
AULTD
peterban's Avatar
This seems like a great idea.
Got any photos of you doing that?
Do you inject from both sides or top and bottom? How far in do you have to get the needle, as there doesn't seem to be much room to get the needle in between to squirt the grease in
peterban is offline   Reply With Quote Multi-Quote with this Post
Old 19-11-2006, 11:33 PM   #20
peterban
AULTD
peterban's Avatar
Cheers,
GK
Sounds like it might be another GK "how to".
I hope so as I am getting some knocking noises in the front suspension.
