08-11-2006, 02:53 PM | #1 | ||
hey all
I have vn calipers and borg warner drums on my mark 1 capri I want to put a larger master cylinder on the car does anyone know of anything that will bolt up easily that has a larger internal bore? cheers Quinton |
08-11-2006, 03:27 PM | #2 | ||
Apparently you can use one off a Rover SD1 or even a Range Rover so I have been told. 1" bore & a bolt on fit.
08-11-2006, 06:04 PM | #3 | ||
mk 1 capri
apprently one of a centura will bolt up to a 4 cyl booster and run a four wheel disc brake setup.not what you got but a bit of useless info.
source-hoppers stoppers |
09-11-2006, 08:05 AM | #4 | ||
Yes, think big british cars of the same era. Land/Range Rover, I know for sure fits. I think you can even use one from a Jag.
