Old 24-10-2006, 03:26 PM   #1
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
Default Tail light wiring
Quick question peeps...
Is there a difference in tail light wiring between AU sedans, utes and wagons?
Doesn't matter what series.
EDIT - I know about utes in that the reverse light is located in the rear bar... I'm more wondering about if sedan/wagon tail light wiring would wire up OK on a ute.
Carless
TheSneakiness is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2006, 04:26 PM   #2
The Monty
Just slidin'
The Monty's Avatar
Your not putting AU sedan taillights on the axe are you Kenny? That would be something very different, lol....
MD Mondeo - For the family
NP Pajero - For the adventure
The Monty is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2006, 04:35 PM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
Remove you taillight. Find the reverse light bulb and holder ( clear, single element bulb with 2 contqcts on the buttom..or just take noote of where you unscrew it from :P)
Then just cut off your reverse light plug with a 3 inch tail... solder or crimp some extra wire to the loom end, run it to the bumper then rejoin the bulb holder (if the rear bar one is the same size bulb as the taillight of course)
If the rear bar takes a smaller bulb just get a new bulb holder from ford
Racecraft is offline   Reply With Quote Multi-Quote with this Post
Old 24-10-2006, 05:08 PM   #4
TheSneakiness
Adapt or perish...
Nope, nope, nope.
Originally Posted by Racecraft
Remove you taillight. Find the reverse light bulb and holder ( clear, single element bulb with 2 contqcts on the buttom..or just take noote of where you unscrew it from )
So, if I took out the reverse light wire from the rear bar, and joined it up with the reverse light from a sedan loom, it would still function OK?
Carless
Old 24-10-2006, 05:31 PM   #5
Racecraft
they call me Tibbo
Racecraft's Avatar
join them to your existing loom... forget the sedan one.. just use yours
Old 25-10-2006, 08:46 AM   #6
TheSneakiness
Adapt or perish...
Ah.
Thanks Tibbo...
Carless
