Old 24-11-2024, 08:03 AM   #1
AlCan
Crazy Mondeo Fan
Default TDCi DW10 Engines: Cam Chain Oil Supply
Hi Guys,
A while back AlanM and I touched on the reliability of the inter-cam timing chain when subjected to poor maintenance. Apparently, if (oil changes are) neglected, it is prone to early severe wear, perhaps in some (2.0?) TDCi engine variants more than others. Now I'm wondering, why the chain, in particular?
Can anyone comment on this, please?
I recently bought a 2013 MC Wagon (TXBB? / DW10C engine), 133,000km.
The first time I started it after buying it - after it had been sitting for a while - I noticed that the cam chain was quite noisy. I noticed this again the next time also, when I was showing it to a friend and just figured, we've got a worn chain.
However, this time, while we were standing chatting in front of the idling engine - bonnet open with "beauty cover" off - I noticed that the chain was suddenly becoming quieter. It continued becoming quieter and quieter until it was barely noticeable. This took maybe half a minute - after already running for a minute or two.
Clearly, it was suffering from either lack of lubrication, or lack of tension - or both. Based on this observation, the oil flow to either the chain or (maybe?) the tensioner is very limited - maybe almost blocked?
My question for AlanM or anyone who might know: what does the Oil Supply to the cam chain consist of? Is it a small-orifice jet or spray, or is it merely splash from some other source? What's the chain tensioner situation - is it oil pressure driven? I suspect from watching an Alan Howat video that it is, but I don't think it was confirmed in the video.
The next question: what would it take to clean / fix it?
Any suggestions, please?
AlCan is offline   Reply With Quote Multi-Quote with this Post
Old 24-11-2024, 08:08 AM   #2
Default Re: TDCi DW10 Engines: Cam Chain Oil Supply
Start by looking at parts diagrams for the valve train, to identify related elements. That will show if (for example) there is an hydraulic tensioner or filter screen before one.
Then you can look up the elements using part numbers and Google Images or Fleabay, to get a clearer idea of how they are in real life. The frequency with which a valve train element is offered for sale (like the BMW N46 models for which you can almost buy timing chains at the corner shop) often is a clue about component longevity or reliability.
For example:
https://www.ilcats.ru/peugeot/?funct...4A&language=en
Then you look up part 084922…
https://www.google.com.au/search?q=peugeot+084922
(I didn’t include the Google Images link as it was chockers with identifiers.)
In this instance, there doesn’t appear a huge market for link chains and guides, tensioners; this leads you towards the notion they’re fairly durable.
There is a sprung ball check valve, Peugeot number 023527, between the block and head (these normally are pressed into the head). It’s found on the pages detailing head gaskets etc.
Old 24-11-2024, 08:48 AM   #3
AlCan
Crazy Mondeo Fan
Thanks Citroënbender for your most helpful reply!
These Russians, eh? Often, they seem to know more than anyone. I watched a Russian YouTube Video on an MPS6 teardown - excellent, despite the auto-translation not being that great.
You have prompted me to dig further into the Tech Resources section and finally have found the MC Mondeo WSM https://www.fordforums.com.au/vbport...articleid=1882- but haven't figured out how to drive it yet... Some of the "links" don't seem to work? Haven't yet got to the section in question.
Yes, it seems like cam chains etc are not a commonly failing item - except where as AlanM suggests, maintenance has been neglected, which is sounds like it has in the case of this engine. Of course, I'd like to see if I can stop this problem before it gets any worse, and I'm suspecting partially blocked or gunged up somewhere there. I guess once dirty oil gets into the tensioner, it's hard to get it out?
Old 24-11-2024, 09:22 AM   #4
Chain tensioners of fifty years ago, often used to have a mesh filter screen - wouldn’t be surprised if this detail is long gone.
Excepting the polymer tensioner shoe, the rest of a unit can usually be dismantled and solvent cleaned off the car to restore function. Ones with a strong spring element (that moves quite a bit) may suffer ageing of this part, but most designs are simply to take up progressive slack - not large fluctuations like a serpentine belt tensioner.
Always worth familiarising oneself with how to retract and then release pre-tension in hydraulic units, at least these are a simple grenade pin type.
Old 24-11-2024, 12:15 PM   #5
AlCan
Crazy Mondeo Fan
I found a 6-year-old video by Alan Howat (he looked so much younger then) that covers the whole thing - more or less. He's quite funny, ol' Alan.
https://www.youtube.com/watch?v=ewV0i9MqMb8
It looks (and as he makes clear!) like quite a mission to replace that chain - far better to just change your oil on time, like he says. There is also a very helpful comment in the Comments (where else!?) by @Sergiu_K about not getting any sealant down the hole that feeds oil to the cam chain tensioner.
Although Alan doesn't mention it, it's pretty clear in the video that there's a hole in the bottom of the tensioner "foot". This, surely, is the hole that supplies oil to the chain itself. Since it's coming out of the tensioner plunger, it must be fairly small, so as not to drop the pressure inside the tensioner cylinder, but whether my partial blockage is there or upstream of the tensioner...
The link again
Although it's apparently (Windscreen sticker) not due for an oil change, I think I'll do that first and see if it helps.
Oh, regarding the TechResources WSM - it looks like the way to navigate it is to find what you're after in the Index, then go to that section then manually scroll down the page (or search by section) to find what you're after. There's a lot of great info in there, but the Alan Howat video is the best overview.
Thanks CB for your excellent insights.
Old 24-11-2024, 12:20 PM   #6
AlCan
Crazy Mondeo Fan
Hole in foot: Alan Howat vid at 3:34
Old 24-11-2024, 02:41 PM   #7
Wouldn’t worry about it.
Had a Ford tdci 2 litre sold it at 278000kms
Never was the quietest engine at start up
All those Ford engines even petrols (Refer to Euro s) noisy on start up then quieted
Of that era.
You can keep driving those engines till the wheels fall off
Also they are a shared Peugeot - Ford design - I had the chain tensioner replaced at 180/200000 what ever the book said - by a Peugeot specialist.
Franco Cozzo on here had one too and his with another owner and neglected is over 250000kms
kevino is online now   Reply With Quote Multi-Quote with this Post
Old 24-11-2024, 03:11 PM   #8
AlCan
Crazy Mondeo Fan
Thanks! Would love to be able to take that advice!
However, I have a 2011, done 259,000km, one prior owner, fully maintained, no noticeable cam chain noise.
In contrast, the 2013, 133,000km but already 4 or 5 prior owners, (was cheap, but) probably badly maintained, already has this problem. I was hoping the 2013 would replace the '11 as that one has clutch/gearbox issues...
You know what they say - the best laid plans... But I was hoping the '13 would keep us on the road. I'm hoping that if I can get the tensioner sorted, it might be ok.
Oh, and, I've watched too many Alan Howat videos...! It looks to me like lack of clean oil causes these issues, and it seems, once it starts, it's one way.
Old 24-11-2024, 04:48 PM   #9
AlCan
Crazy Mondeo Fan
Originally Posted by AlCan View Post
Oh, and, I've watched too many Alan Howatt videos...!
Like these:
https://www.youtube.com/watch?v=UBs1FLVyxdk
https://www.youtube.com/watch?v=aVFa8H1RpSY
https://www.youtube.com/watch?v=-jLzRoDQdyo
https://www.youtube.com/watch?v=08VYLAQ5xr0
It looks like the MD has many more cam chain issues than its predecessors.
The cam chain is a redesign, which on the face of it, looks like it should be good. It saves space by turning the tensioner the other way up, allowing an oil filler / handy cam chain inspection hole to be placed in the rocker cover, but this may be also be why it seems to fail so often.
In the earlier models, the cam chain tensioner presses down on the upper pass of the chain. This causes the chain to wrap further around the sprockets as it wears. However, the new design pushes UP on the upper pass of the chain, which has the opposite effect. I can't see that that's a big deal because either way, it's on the slack pass of the chain, and because the presser foot is facing upward, you'd imagine, if it's still pushing oil out through a hole in the foot, that this would lead to improved oiling of the chain, but they seem to snap more often. Maybe they reduced the oil supply at the same time, making it more prone to blockage?
However, when you look at the way the chain sits when the tensioner is not tensioning, such as at 7:48 in the https://www.youtube.com/watch?v=aVFa8H1RpSY video, you start to get an idea of what might be happening.
With the tensioner pressing on top, it's working in the same way as gravity. The chain will naturally hang down even if there's no tensioner, and the tensioner plunger itself will come to rest after a stop, hanging down on the chain after the oil has drained away. The spring inside it will ensure that too.
However, in the case of the tensioner pushing upwards, once the internal spring breaks, the tensioner will drop over time causing the chain to take on an M shape as per 7:48. It's easy to imagine that when the engine starts from cold with no oil pressure, the slack chain coming off the driving sprocket (LHS, [rear] exhaust cam) is going to crash into the side of the tensioner foot, and if it's a bit worn and stretched, it's likely to jam and be dragged between the tips of the sprocket teeth and the side of the tensioner. It can only break...
I would almost guarantee that's what's causing these chains to snap. I haven't surveyed it, but I'm willing to wager that snapped MD chains always have broken tensioner springs (first). And that they always break on startup, after a longer period of not running.
Howzat, Alan Howatt?
Old 24-11-2024, 05:00 PM   #10
Maybe post on whirlpool automotive it’s a bit quiet on here unless it’s falcon- ranger- Everest
Old 24-11-2024, 06:32 PM   #11
AlCan
Crazy Mondeo Fan
Very true, will take a look - not signed on there yet.
On this whole MD tensioner thing - the old brain is like a dog with a bone...
It's odd that Alan Howatt simply replaced that broken chain, tensioner etc without knowing what caused the chain to break. In the video with the split sprocket hub and the missing teeth, it's probably the same thing? In that case, you'd think there would have to be gouges or marks in the side of the tensioner to show what happened, if this theory is correct.
ANYWAY, another thought occurred to me.
This is going to depend on lots of things that I don't know about. Citroënbender mentions that there's a ball spring check valve in the oil gallery feeding from the block into the head. That's a good idea, to stop oil draining back from the upper oil passages during shutdown, but what if there are oil passages opening in the head, below the level of the tensioner cylinder? For example, oil passages feeding each cam journal. It looks to me that the cam lobes press downwards onto the rocker arms.
This means the cams are likely to be in a lifted position in their journals during shutdown, pushed upward by open valves. If the journals are worn, or the oil is fed into the lower side of the bearing, then oil could siphon out of the tensioner cylinder. It will be able to do this if there's (still) an oil passage feeding from the tensioner cylinder through the piston and out onto the tensioner foot. This drilling will allow air into the top of the piston & cylinder, allowing the oil to drain out somewhere lower in the head.
So, after standing a while (esp from hot), the tensioner cylinder could be largely full of air. Air, being of much lower viscosity than cold oil, on startup will simply jet out through that opening until the cylinder is completely refilled. No oil pressure will develop inside the cylinder until then. Since the inflow must be restricted, this could take many seconds - based on the time it currently takes for my MC cam chain to quieten down on startup. During that time, the tensioner will only provide spring tension - if the spring is still intact. If it's not, the tensioner won't provide any tension at all.
A Dangerous Time, given the jarring path the chain will follow leaving the driving sprocket. This all seems to be supported by the fact that in one video, the tensioner foot was broken off and the piston out of the cylinder...
So, MY SUGGESTIONS if you have an MD Diesel.
Keep an ear out for cam chain noise on startup.
If you hear it, or, maybe monthly regardless, with the engine Off - of course - look through the top oil filler hole and see if the cam chain is being held upwards under tension by the internal cam chain tensioner spring. If it's not, get a new tensioner fitted ASAP!
Old 24-11-2024, 10:19 PM   #12
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Of that era.
I even bought the chain to have it replaced with the timing belt, and the workshop didn't bother replacing it
Mine was fine, car is still around with over 250,000km at its new home,
To put it into perspective, that thing survived me ripping skids in it on my Ps, hand brake up, clutch dumps, I put it down the drag strip 6x, towed overloaded 6x4 trailers with it and it carried tools around for me, thats how I treated that thing and the cam chain is still quiet.
She's a bit tired now though, last time I drove it, could tell some of the ponies have left but its probably 70%.
Old 25-11-2024, 06:20 AM   #13
AlCan
Crazy Mondeo Fan
EEeeee! Well, I got that wrong... Watched some of the video of the split cam sprocket hub again.
Having an intact tensioner spring is no guarantee that your MD chain won't break. So I guess the overriding thing is chain wear, which comes down to chain lubrication.
Franco - Thanks for your adventurous account! What a machine! Yes, I believe these engines are very durable and can take a thorough hiding, so long as the oil is maintained. Howatt's taxis have been getting much higher k's - equal numbers of MILES! Like I say, my 2011 engine has even more k's on it than yours, and is still going strong. Maybe 90% of its ponies still home. It even still has its original EGR valve still connected and working correctly (touch wood), so it hasn't had a lazy life. (Haven't tried disabling that one [no need anyway] as it has an ECU return signal so would probably throw the Mother-In-Law light...)
I've towed a fully loaded, covered 8x4 trailer to the South Island multiple times - it gets around 8l/100km on those trips but can still get 5.6l/100km on a trip through snow and ice in Tiptronic mode (without trailer of course). And the cam chain is still quiet...
Old 15-12-2024, 01:07 PM   #14
AlCan
Crazy Mondeo Fan
Citroënbender, if you are about, would you mind giving me another of your great insights into these engines, please?
I'm just back from visiting the 2012 Zetec - the one with the slipping clutches - much improved now.
However, the list of its other faults keeps growing...
Still on the cam chain tensioner / lubrication system, after sitting for a few days in warm temperatures, I started it the other morning with a 10°C ambient. Not cold... This time, I timed how long it took at idle for the cam chain to quieten down after a cold start. As normal, the oil pressure light went out immediately, but the cam chain rattling continued for seven long minutes before it finally went away.
This is scarily long in my book, and I guess it can have only three causes:
1. No Oil to the chain;
2. Very little Oil to the Chain Tensioner cylinder / piston;
3. The piston was stuck and very reluctant to move.
I'm guessing it really comes down to either a sticking piston or a nearly completely blocked oil feed to the tensioner, and maybe it has to be pulled apart either way.
My question is, - you've mentioned the check valve already - but do you know what restricts the oil flow to the tensioner? Is it a flow restrictor orifice in the tensioner itself, or is it elsewhere?
What I do now know is that this engine has had the wrong oil in it for a while (before I bought it). Maybe for a few "services" by the last owner's local garage. They used Pennzoil Synthetic 5W-30, which is not Ford Approved. None of Pennzoil's products appear to meet 913-A, B or C.
I changed this immediately after detecting this long startup rattle but had to leave that afternoon. Wanted to get some clean, approved oil into it anyway, in the hope that it can dissolve whatever the problem is while I'm away, but suspect I'll have to pull it apart anyway. Or can you make any other suggestions?
Old 15-12-2024, 02:29 PM   #15
There’s bound to be somewhere in the block that you can tee in a mechanical oil pressure gauge. Perhaps try that first and look for any obvious correlation with the noise.
Old 16-12-2024, 07:12 PM   #16
AlCan
Crazy Mondeo Fan
Good idea, CB. The easiest place is below the Oil Filter/Heat Exchanger, where the Oil Pressure (Switch?) screws in. No doubt, that's a Metric thread. 10mm?? Pitch I'm guessing 1.0mm. Will find out.
Am I correct in thinking that there is no Oil Pressure Sensor, just a simple Low Pressure Switch?
Anyone know if there's an OBD value anywhere? I guess I'll test what the Info Display does if there's "Low Oil Pressure" and let you know.
Old 18-12-2024, 07:22 AM   #17
Mondaveo
Mondaveo's Avatar
I jumped into FORScan to take a quick look for you. All I found exposed through PCM when I searched 'oil' was one PID, LOW_OIL for Oil Level Status, with values Yes/No as shown in screenshot. You are correct there does not appear to be any sensor giving a continuously variable value you could read for oil pressure.
2011 Mondeo MC Titanium TDCi wagon, Panther Black
- new Powershift sensor: Nov 2016
Originally Posted by rondeo View Post
Like 'Mondeo' is possibly Latin for gearbox anxiety.
Mondaveo is offline   Reply With Quote Multi-Quote with this Post
Old 19-12-2024, 07:15 AM   #18
AlCan
Crazy Mondeo Fan
Hi Mondaveo,
Thanks for doing that, and the screenshot. As we suspected. I guess, it makes sense, but didn't get around to testing what happens when the switch continually says Low Oil Pressure, just yet.
Anyway, this all brings me to my next hurdle, and you may be just the man to ask?
Except, I've just now discovered, this hurdle has suddenly grown a whole lot higher.
A while back, after reading some of the FORScan website, decided to buy a vLinker FD (Bluetooth model). It arrived, and I started trying to get it to work yesterday... First up, it wouldn't connect to my Android 10 cellphone. It pairs, but won't connect. Played about and searched the net, seems to be possibly an Android issue. (More on that later.) Got it to connect to an old Android 4.4 phone. All Good. Got FS Lite installed on it too. Then tried to activate FORScan Lite.
BAD TIMING. And Bad News for everyone wanting to start using FORScan. On Android and Windows anyway - of course, my two preferred platforms.
Kept getting: "The action is temporarily unavailable" when attempting to buy an Activation Code for the Lite version.
This morning, the same, and now I see the following message on the FORScan site:
Products
Sorry, we have to suspend sales of FORScan licenses for Windows and Android (more information).
This happened yesterday, and it's Political - FORScan has been at war with Google https://forscan.org/support/show_con...through_google, and now, the US sanctions against Russia are biting.
I haven't tried to get a License through Google yet - reluctant to do, but maybe I need to hurry up. But probably won't be able to, using the old phone... Or the newer one. Seems like Google might have deliberately blocked this connection in newer versions of Android... Not Google's biggest crime, but seems it's getting bolder.
Will keep you posted...
Old 19-12-2024, 09:20 AM   #19
That’s unfortunate. Similar happened when Junior marched his troops deeper into Ukraine early 2022. There will be ways around it - perhaps see if there’s a ForScan Telegram channel.
Edit to note, I’ve had a moderate poke around and can’t find anything - even Russian users are complaining that admin of the support forum are slow in responding. There could be a number if reasons why… A shame it’s this way overall, I think sharing knowledge is a step towards more open communication in the world - and less conflict.
Old 31-12-2024, 10:03 AM   #20
AlCan
Crazy Mondeo Fan
Brief update:
As you might have seen, got a FORScan setup (Windows, "Extended" Licence) working, just can't do any PATS stuff yet.
Still working on an Oil Pressure gauge. Metric fittings hard to find over here. I believe it's a 16mm thread into the block... Want to Tee it with a pressure switch to keep it "standard".
Also, the Cam Chain Noise thing. Started up the old '11 after it's been sitting for a few weeks, and paid close attention to the cam chain sound. Amazingly, went quiet after about 15 seconds. That's a great engine! Been fully maintained all its life, now at 259K.
In contrast, the '13 with the other issues is still "variable" to say the least. Definitely need that oil pressure gauge connected. Some days, it goes quiet within 10-15 seconds after an overnight rest, but the other day (also overnight), took more than 90 seconds before I got tired of waiting. Oil light off quickly as normal though.
Worse, it seems that often (always??) after a full warmup, the chain noise returns.
This cannot be a good sign.
I'm not getting any low oil pressure lights coming on, but now beginning to really wonder what's going on. I have to conclude that this engine has been very badly neglected at some stage in its young life, and maybe it has worn crank bearings. It does make a bit of (Big end? Combustion?) noise on startup, but that always goes away very quickly. Or, maybe it's just that the tensioner cylinder is all gummy and the spring is broken???
Old 31-12-2024, 10:49 AM   #21
Re ForScan, as of two days ago there was a (third party) purposely set-up FB group to funnel payments into the Russian bank. Pretty much at net (not “nyet”!) cost, they were working in English.
I can’t say offhand whether paying to a Russian entity in this way, contravenes Australasian laws of business engagement relating to what Russia is presently doing elsewhere, but probably not.
Old 31-12-2024, 01:04 PM   #22
AlCan
Crazy Mondeo Fan
Thanks CB, might look at the NZ rules, see if I can find anything. Cheers
Old 01-01-2025, 02:09 PM   #23
goz007
Diesel Sniffer
goz007's Avatar
Brief update:
Interesting read & yes i to have looked into this chain & its set up(after just completing timingBelt W-pump on my MD)my 5cents worth, from this post is(all along im thinking internal spring is lazy & oil pressure is making up the slack over time) but from what u describe here with the Hot start noise sounds like the tensioner has a bad seal/piston....either way if u want to sort it id say u are R&R the tensioner.....as for the pressure light most of those pressure sensor/lights will switch the light off at about 7psi, as suggested u will need to plug in a mechanical gauge to know exactly what goes....(but if pressure was low id say u would have more issues than a noise in the cam chain-& im putting my money on a worn shaft/piston inside the tensioner combined with a half bad seal that is letting tension/pressure go, then once it all heats up & expands it eventually finds its happy place seals & works as it should-sometimes faster than others....)
goz007 is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2025, 04:50 PM   #24
AlCan
Crazy Mondeo Fan
Happy New Year goz007,
Thanks for your comments - I agree 100%. It's looking more and more like the only way to solve this is to pull it apart to get that tensioner on the bench.
Yep, possibly the cam chain is the least of the problems, which is kindof why I haven't put full effort into the Oil Pressure gauge. If you've read my other posts, this is the same car that's got the weird 3rd to 1st gearchange issue and I'm mainly focused on that for now. The car has an ant farm of small problems. I grabbed it because it was sold as dud transmission and was hoping the 133K young engine was okay and trans fixable, but it turns out almost the opposite.
Maybe I'd better flip back to that thread because I've done a bit more on that - made no real progress - except that I'm now suspecting that problem and this one have the same root cause... Serious neglect of oil changes. Again, as many questions as answers though.
Old 02-01-2025, 12:23 AM   #25
goz007
Diesel Sniffer
goz007's Avatar
Ahh sorry haven't read it(if I get time I will).... interesting what u say about the ant farm though, my MD is exactly the same, I've set off two any/pest bombs in it sprayed all the door jams but the buggers keep coming back(I think there's a nest somewhere in it behind a panel, I recently(last week)did the timing belt/water pump/thermostat & reseal of the H.P.F.P and when I had the inner guard off the front wing they were everywhere up inside there(even after the considerable amount of heat I pumped into the front pulley bolt before trying to remove it-it got that hot the top of the R/H wing was hot to touch) I also pumped anthor 1/2can of spray in there before refitting the inner guard but they were still hanging around in the engine bay....I'm thinking it's time to get rid of it..... in worried of the electrical issues they will eventually inflict on it
Old 02-01-2025, 08:28 AM   #26
AlCan
Crazy Mondeo Fan
Wow! You've got some stubborn little mongrels. Yeah, I'd be worried about the longer term damage they will cause, too.
I've had a number of experiences with the little blighters and can't imagine why yours are so determined to stay. Understanding their habits may help.
First up, they nest near their food sources. Are your rubbish / recycling bins nearby? (I guess you have...?) Look around for ant trails heading in that direction, and if so, then move the bins far away for a while.
Is the interior of the car clean - no fast food debris down beside the seats etc? Assuming there's no handy food in the car, then they have to be trekking out to get it. Best if you can get them when most of them are "out", then lay down a wide and heavy ring of spray around each wheel. If they can't cross that, the problem will resolve. Also, park your car in a different place every day/night. I'd try that immediately.
If that doesn't fix it: I've found that generally the best way to get them to move house is to "scare" them. For some reason, they really don't like vibrations, which makes it hard to understand why they'd choose your car. Anyway, if you can pinpoint where the nest is, get a plastic fly swatter or similar, and spend a few minutes whacking the panels all around that area. You might want to protect your paint with a sheet first... But, if it's working, they will all start moving out. Come back later and repeat, several times. They'll get the message.
Hopefully, it's in an exterior part of the bodywork, as if you do this, they will probably also mark the location with some kind of long-lasting "stink" chemical, to remind themselves and any others never to nest there again. I've got a spot like that (some cupboards) in my garage, and I can still smell it, years later. No more ants though!
Good Luck!
