07-01-2012, 09:20 AM | #1 | ||
66 Mustang
I'm confused about how to fix the timing tensioner leak in an AU,
Is it just a case of removing the P/S pump and brackets and tightening the tensioner bolt up without removing anything else and putting the P/S pump back on and done? I have already done the front crank seal so it's not that, and I can see the oil stains on the block under the P/S Pump |
07-01-2012, 11:24 AM | #2 | |||
Next upgraded Mk1 Leopard
I have done a how to in my build section http://www.fordforums.com.au/showthr...1238536&page=7 BUT be careful. If you don't want the hassle of re-setting the tensioner, get some gasket goo and only loosen it. Clean and put on the gasket goo and re seal. When I undid mine the centre bolt wasn't leaking just the larger sleeve. Hope this helps UK
07-01-2012, 06:57 PM | #3 | ||
66 Mustang
So back it off, wipe it with a rag, gasket goo and tighten back up?
07-01-2012, 07:41 PM | #4 | ||
both mine and my dads au's were leaking about half a turn was needed to tighten it back up, then no more leak... i didnt even take the bolt out and no gasket goo required...
07-01-2012, 07:48 PM | #5 | ||||
AU DIE HARD
07-01-2012, 07:55 PM | #6 | |||
UK
07-01-2012, 07:56 PM | #7 | |||
UK
07-01-2012, 08:07 PM | #8 | |||
AU DIE HARD
07-01-2012, 10:00 PM | #9 | |||
Shayne93 lets us know how it goes. UK
08-01-2012, 04:16 PM | #10 | ||
66 Mustang
So go just one or two turns back, gasket goo or thread tape then tighten up?
Dont need to reset timing? |
08-01-2012, 05:13 PM | #11 | |||
UK
08-01-2012, 07:05 PM | #12 | ||
66 Mustang
Why must they be so difficult and tempremental grr :@
08-01-2012, 07:11 PM | #13 | |||
UK
09-01-2012, 07:59 AM | #14 | ||
66 Mustang
When I tighten it up I tighten it up real well?
09-01-2012, 09:52 AM | #15 | |||
The goo will squish out ofcourse, just run your finger around to help the seal. UK
