Old 06-10-2011, 10:01 PM   #1
Morry57
FPV170
Default help asap....
hi xr8 is making clicking sound when starting? Thinking starter motor....? Any helpbe great cheeers???
Morry57 is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:08 PM   #2
Bunyip04
Think Heavy..
Bunyip04's Avatar
Default Re: help asap....
Sounds like a bat flattery !!
________________________________________
07 BF MkII BOSS 260 XR8 6spd manual! EGO
There's no replacement for displacement!!!
Handling: Bilstein Shocks with King springs all round, Whiteline 27mm front swaybar & 22mm rear adj, upgraded PBR rotors, calipers and braided lines all round with Bendix Ultimate pads.
Go Fast Bits: Herrod C.A.I with K&N 4" pod flter, Herrod Helix spacer, Herrod oil breathers, Tridon 72c thermostat, Herrod 2.5" stainless cat back zorst.
Bunyip04 is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:13 PM   #3
Pedro
Pedro's Avatar
bas afove
The clicking is the solenoid caused by your fattery being blat.
Pedro is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:18 PM   #4
Morry57
FPV170
tried jumping but to no avail??
Old 06-10-2011, 10:21 PM   #5
Auslandau
335 - STILL THE BOSS ...
Auslandau's Avatar
Sure the flattery you are using isn't bat as well?
'73 Landau - 10.82 @ 131mph
'11 FG GT335 - 12.43 @ 116mph
'95 XG ute - 3 minutes, 21.14 @ 64mph
101,436 MEMBERS ......... 101,436 OPINIONS ..... What could possibly go wrong!
Clevo Mafia
[SIGPIC][/SIGPIC]
Auslandau is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:25 PM   #6
lockieoc
I've had batteries so dead that I couldn't jump them. As above bat flattery
lockieoc is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:27 PM   #7
05_ENFORCER
05_ENFORCER's Avatar
LMFAO
2015 FGX XR8 5.0 S/C 645 RWKW
05_ENFORCER is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:28 PM   #8
Bunyip04
Think Heavy..
Bunyip04's Avatar
Might have try buy a new one, process of elimination from there.
Old 06-10-2011, 10:32 PM   #9
Morry57
FPV170
tried battery in another car started no worries.....
Old 06-10-2011, 10:34 PM   #10
Bunyip04
Think Heavy..
Bunyip04's Avatar
Hmmmm, ignition relay...?
Old 06-10-2011, 10:34 PM   #11
Paxton
Cobblers!
Paxton's Avatar
Are you in Park or Neutral?
Ego BFII Ghia
Titanium Silver E53 X5 4.4i
Gunmetal EF XR6. Now retired from active duty.
Roses are red. Violets are blue. OS X rocks. Homage to you.
Paxton is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:35 PM   #12
falconhell74
falconhell74's Avatar
tyr removing the leads from battery & jumpstart with leads disconnected , if it starts then battery is totally fubar, If you have multi meter load test battery put leads from meter to battery terminals & turn key if voltage drups below 10.5 volts battery u/s. if power all good check power to exciter wire on starter should have battery voltage when cranked, if not replace starter relay as it could be burnt out/ still clicking over but no voltage output, if you have battery voltage at exciter wire then starter u/s
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:38 PM   #13
Geez Louise
Awesome
Geez Louise's Avatar
Location: In my own little world..Everyone here knows me :)
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind the scenes things that help the community.
Great post. There is some good advice right there.
Geez Louise is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:44 PM   #14
AWD Chaser
Formally Kia Chaser
AWD Chaser's Avatar
Had this issue recently in my HSV - 3 batteries would not kick it over, but they worked in other cars - car would jump start, but no battery power while driving (only running on alt).
I could get power to the dash, but no crank, But there was no voltage drop on the bat when cranking.
Turned out I had a corroded terminal which was preventing enough current flowing to kick the motor over, but enough to run the electrics before cranking....
Kia Grand Carnival (2006)
Silver, Grill Mesh, Tints, Sidesteps (with lights), Towbar, 7" Touch Screen DVD Tuner with intergrated GPS & Bluetooth, Roof Mounted Flip Down 15.1" LCD Screen, Reverse Camera - 184Kw
HSV Clubsport R8 VY (2003)
Black, 6sp Manual, Coulson Seats, Red on black interior, Pacemaker extractors, Twin 2.5" exhaust, Custom Red 20" VE GTS Rims, Custom Red Stitching
AWD Chaser is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2011, 10:47 PM   #15
05_ENFORCER
Yep, dud cell I reckon.
These newer Fords need a good dose of current to fire them up.
Computer says no!
