Hi,
I have a problem when putting petrol into my AU1 where the fuel wont flow continuously, the trigger on the bowser handle keeps clicking when trying to fill up at every garage. Very frustrating. thanks. |
pursuit ute baby
try positioning the nozzle back a bit, change the tilt.. sounds like youre getting splashback and the fuel sender unit thinks your tank it full.
Don't push the nozzle all the way in, have it just a bit inside the hole.
BA Xr8
Also look in the tank opening, you should have a flap (looks like a trap door) covering the opening that opens inwards when the nozzle is place in the tank. Sometimes this can come off and sit further down the tank opening causing this problem.
AFF Whore
I have this problem just about every time I fill up, usually if I 'just' push the flap in, then start to fill its ok
![]() Join Date: Jan 2005
I never have a problem when I fill up. But then mine's LPG.
Try jiggling the petrol nozzle around a bit and have it sitting just out (ie not all the way in).
Cruising...
Its your AU telling you that it wants the premium stuff
FBT '98 BA XT '04 F100 4x4 '82 Subaru Outback '02 |
Never late with a V8
sounds like your breather could be blocked...
My Rides (Daily)2004 Explorer V8 Limited (Project/Cruiser)XE Fairmont Ghia- 351 Cleveland, Toploader (Work) 2014 Kenworth K200 Aerodyne (Classic) 1969 Mini K, 1340, twin SU's The beginning is near!!! Body by Ford. Soul by NudgE
Resident AFF detailer
IIRC Falcons have an S-bend at the start of the tube going into the fuel tank...
Turn the pump nozzle on a 45 deg angle next time you fill up, I've never had any problems with splashback doing this.....
Loving my '335' kW!
Seen this thousands of times managing servos, what I do is put it in the whole way, with some slight down pressure, then pull it out a little and wait for the nozzle to drop down. As soon as that happens, it should be in the optimum angle for a full fill.
Sounds like a dopey way, but sometimes it's hard to picture, and this is usually the easiest way of describing it.
FG X XR8 in Smoke. Smokin the tyres, that is! XR8 logo pic taken at Avalon Airport, Falcon Fanatic filming 17th October 2014 |
Mine only does that at one servo near me, all others are fine. I found rapidly 'pumping' the trigger repeatedly gets it to work, but as I said, thats only at this one servo.
05 BF XR6 ZF 6spd - Stock for now Previously: 98 AU Futura 4.0 - Wildcat Extractors, 200cpsi Stainless Cat, Custom 2.5" Mandrel Bent Exhaust, Tickford Snorkel, Fram 'Airhog' Panel Filter - Daily
79 P6 LTD Silver Monarch - Project |
#12 | ||
Mine had the same problem filling at all pumps. It started off doing it only only a few but got worse over time. The problem is with a little flap that Ford have fitted to the filler socket. It breaks off after a few years and catches in the filler tube,then the filling problem starts as the petrol back pressures trying to get past it. I used a piece of coat hanger wire with the end tightly bent over to hook the flap and then pull it up to the top of the filler socket. Onse you can see the flap, I used a pair of needle nose pliers (long nose should do it ok) and removed the flap. The car now fills to full without cutting off the bowser at all.
#13 | |||
I have tried not inserting the nozzle to far in, turning it in on an angle, still not working.
#14 | ||
Steve
It is a fault with the anti siphoning flap in the top of the fill tube. My TE50 had the same problem ,it took ages to get a few bucks in . Search the T series room,I am sure there is something in there about it.
I had ford fix mine under used car warranty.
Currently no Fords . 2005 Statesman International 5.7, Mazda 2 and a Hilux. Former Fords: 2010 Ford Escape 2007 BF11 GT, TE50 Series 1 ,AU V8 One Tonner ,EL Falcon Wagon, ED Fairmont , EB Falcon Series 1. Mk 2 Cortina Company Fords : 3 BA Falcons , EB 11 Falcon Wagon , Ford F350 351 V8. |
#15 | ||
Yeah the flap was missing and also the tank was leaking so i picked up another tank and all problems fixed.
#16 | ||
All sounds a bit porn related IMO
IF YOU CANT FIX IT WITH A SCREWDRIVER OR SHIFTER , F%$K IT with a hammer - Light travels faster than sound.......this is why some people appear bright until you hear them speak! AU SERIES 3 LIQUID SILVER BBS MOTORSPORT RIMS , EIBACHS , BILSTEINS , CERAMIC COATED 4499 PACIE'S , 2.5 S/S GENIE SYSTEM , MAGNAFLOWS , METALCAT 200cpsi , CAI MODS 123.4 GROUND TEARING RWKW'S , LOL |
#17 | |||
