Hey anyone know how to stop the centre mirror rattling? Im guessing its a pretty common problem, nearly every AU ive been in does it.
'96 EL Fairmont Ghia 5L |
Giddy up.
Mine doesn't rattle, they are suctioned arn't they ? so I don't know why it should be rattling ?.
Im not sure what part of it does it, it shouldnt be the suction part though surely?
Just slidin'
Apparently people tighten them with an allen key.
I just put my wallet on top of it. Just make sure you dont go around corners to fast, as it will fly out the window.
MD Mondeo - For the family
The spring metal clips tend to lose tension. You have to remove the mirror from the mount and prise the metal tangs out again to place more tension on the mount when you push it back on.
PS. There's no Allen head screw on an AU mirror and not everyone's wallet is as heavy as Monty's LOL. PPS. You remove the mirror from the mount by forcing it upwards - takes a good push! |
It usually happens if you play music with a lot of bass, no joke
#7 | |||
Pretty rare I have it up that loud though, only when a good song's on as I prefer the sound of the Windsor shouting back at me. |
macman> That's not your mirror rattling - it is the back window vibrating because the speakers are pointed directly at it.
Its gone V
Mine has an allen key screw securing it to the base wich is glued to the mirror, i know cause it fell on me whilst driving. then removed the base reglued it then refitted the mirror tightened the screw and been good ever since.
From memory it was a 2mm allen key or about there. |
To be honest ive never looked to see if theres an allen key on it, ill go have a look.
Where abouts is the screw soposed to be? Your discription just confuses me hahaha
#12 | |||
Walking with God
You are correct about everything else, perhaps except about Monty's wallet! LOL! GK
#13 | |||
Just slidin'
Yeah! Have you seen how often my car breaks? The only things its full of is receipts, lol.
#14 | |||
Walking with God
![]() GK
#15 | |||
#16 | |||
Walking with God
Glad you didn't offer advice on a Cortina. Wrong thread! LOL! GK
#17 | ||
LOL you're right - that would get me another two demerit points heheh.
And yeah I should have said "his" AU not all AUs. PS. Just in case anyone does want to know how to do a 77 Corty - it's the same as an AUI. But you didn't hear it from me 'cos I wouldn't post in the wrong thread LOL. |
#18 | ||
Virtuous Bogan (TM)
![]() Join Date: Jan 2005
LOL I have the same thing and I have been to lazy to do anything about it, crazes me freakin nuts and depending on the road ill even hold it for a while.
Another little job to do on the weekend. Cheers guys.
#19 | ||
Walking with God
I was thinking about this today. Many insurance companies offer a free windscreen replacement every so often.
It would be easy enough to order a S1 mirror and have the windscreen dude intall this item, rather than the S2-3 item with the clips. As it happens, I actually have another S1 mirror spare, so when I get the window replaced, I'll get that one put in. For what it's worth, I have a S1 and S2, and I've never had an issue with the S1 mirror. Cheers, GK
#20 | ||
I agree ... the older style metal plate on the glass with the grub screw fixture is better.
#21 | ||
mine comes loose about every year but mine has a grub screw so just nip it up every now and then, its from bass and bumpy roads the grub screw is on the part that connects to the window you have to look underneath it
#22 | |||
RIP...
. Oval Everywhere... |
#23 | |||
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust. AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl OWN THE ROAD |
#24 | ||
When in doubt, GAS IT!!
I just had both windscreens replaced last week and I can tell you the mounting isn't on the screen, the fitter will glue it in place before the screen is fitted. How do I know?; I had him raise both mounts up as high as was practical to raise the mirror so I could see under it better. Like the visor, the mirror is too low IMO and obstructs vision, especially if you mount a GPS in the middle of the screen. It's amazing how much better it is being just an extra 20-25mm higher.
Bushbasher
#25 | ||
That's correct - screen comes clean and mirror mount is fitted by the screen guy. Give him the mount you want to fit and he can glue it on for you.
#26 | ||
The only rattle I have in my series II AU XR8 is the bloody mirror rattle!!! It was bugging the be-jesus out of me, so finally I took a long hard look at, and nutted out why it rattles and then nutted out how to stop it WITHOUT REMOVING the mirror !!!
Over years of you, or previous owners, drivers pulling on the mirror to adjust it to their viewing pleasure, the steel block mounted to the windscreen that sits in the metal clip in the base of he mirror does indeed wear and becomes loose inside the bracket allowing the mirror base to "float" in any direction above the windscreen, thus the vibration!!! I attempted to slide the mirror "up" with great force and it didn't budge so I thought bugger this I dont want a cracked windscreen. Then it cam to me, what if I could fill the gap that has been created through the base of the mirror just floating? So I thought what could I fill it with? BLU TAC!!! yup indeed blu tac! It was soft, malleable and it could easily be pushed into all the vacant gaps under the base to alleviate the rattle. So armed with a strip of blu tac and my trusty credit card, I held the mirror away from the windscreen a little creating the maximum gap so I could push blu tac into it. I used the credit card to push maximum amount in all around inside the base nice and neat with none spewing out from the sides. Took me all of a couple of minutes, you cant see the blu tac and the rattle is but of a distant memory!!!
http://i56.tinypic.com/23hlk6p.jpg |
#27 | ||
[ 5L ]
i filled the gaps of mine with selleys no more gaps. haha no more rattles
[ 5L ] 2001 AU series 2 xr8, 220kw, 5speed, leather interior, premium sound, narooma blue, cat back exhaust, k&n filter,willall edit,MSD coil packs, MSD leads, monroe gt gas shocks, superlow kingsprings 187rwkw (mainline) www.ignitionimages.com
#28 | ||
i have only one rattle in my s2 ..........and i put it there when i did a dash out job, later finding out i did`nt need too
#29 | |||
#30 | ||
yeh, old and senile strikes again :(
