20-08-2017, 09:33 AM | #1 | ||
Howdy Folks, I am having an issue with the missus 04 Focus. Sometimes it will not start, turn the key and nothing happens, no click, the lights don't dim at all, just nothing. I know the battery is fine and the battery terminals are clean and tight. Usually if it just sits for a while (1/2 hour) it will start fine. It is very random, the car gets used several times a day and this only happens once a month or so. Any suggestions? other than this problem it runs really well.
Cheers Ed |
20-08-2017, 10:08 AM | #3 | ||
Sounds more like something with the ignition barrel. I've not heard of it with Focus particularly but if it gets started multiple times a day that is probably contributing.
Having said that, it should gradually get worse if that is the cause. Cheers Russ
20-08-2017, 01:30 PM | #4 | ||
Thank you very much for the advice guys, Makes it really difficult to diagnose when it is so intermittent but yes i am also thinking ignition switch issues.
Maybe i should wire in the spare starter button i have for my BA-GT (or not) Cheers Ed Last edited by zeuss000; 20-08-2017 at 01:38 PM. Reason: sp |
