13-06-2006, 09:10 PM | #1 | ||
this is probably an easy fix but for the life of me i cant figure it out.
a setting has been changed on the computer so the blue bar at the top of the screen is thinner, the 3 little boxes at the top right corner are smaller (minimize,maximize and close). this is the same for every browser i use. i dont know if its just me but all text appears to be slightly different in locations such as Favorites, desktop and places like that. any ideas on how to change it back to normal? thanks. |
13-06-2006, 10:10 PM | #2 | ||
Focus on my Focus
Right click on your desktop
Select Properties Go to the "Appearance" tab Click on the "Advanced" button Then click on the part that you want to change. You're probably after the "Active Title Bar" as the item and size 26 would be large. I think thats what you're after.
Now: 2006 Ford Focus LX Manual in Satin White Wife: 2013 Kuga Titanium in Frozen White Then: 1990 Ford Laser - Assasinated by a 76 year old man who failed to give way. Now normally when we have these races, Jeremy goes in the car and says "Powerrr" alot.... - James speaking about Jeremy (Top Gear S7 E05) American parts... Russian parts... ALL MADE IN TAIWAN! - Russian guy in Armegeddon |
13-06-2006, 10:36 PM | #3 | ||
well that seems to bring the top blue bar back to size (around 20ish) but it also increases the bottom blue bar as well which was already fine as it was.
anyway to just change the top blue bar? |
13-06-2006, 11:21 PM | #4 | ||
Focus on my Focus
Bottom bar? You mean the task bar with the Start button?
14-06-2006, 10:25 AM | #5 | ||
yeah. the bottom task bar is fine but the top blue bar is thinner and the icons in it are smaller.
14-06-2006, 06:49 PM | #6 | ||
Focus on my Focus
I'm alittle lost as to what you mean. Theres the title bar which has the red X on the right side. And the only "bottom" bar I have is the Taskbar with the Start button.
Adjusting the title bar size should have no effect on the taskbar.
14-06-2006, 07:21 PM | #7 | ||
02/90 EA II Fairmont
just set it all back to defaults
211RWKW EA |
14-06-2006, 09:57 PM | #8 | |||
the botton bar, which is the TASK bar (with the 'start' button) is just fine and is at normal width. if i change the title bar back to normal size how it was previously discussed, the task bar also increases in size too making it MASSIVELY oversized. i need to know how to change the TITLE bar only. as it sits now, the TITLE bar is about HALF the thickness of the TASK bar. how do i set it back to defaults? |
14-06-2006, 11:10 PM | #9 | ||
sorry this is lazy way but make a new user with same privileges andthen log off and log in and voila ur new default desktop then change your settings to suit....
oh make sure u transfer the documents over before deleting and get your internet andother details handy as u may loose them and the list goes on otherwise if a different user's desktop is fine then write all the setting down under the appearence tab and then make the correct changes to yours its a long shot but will work - there is no default as far a i know sorry i cant help any more falconsr
My Cars: 2002 Ford Falcon AU S3 SR 2006 BF MKI Falcon XR6 2008 Mazda BT50 SDX 2004 BA XR8 ute 2006 AUDI A4 B7 2013 FG II XR6 Ute 2006 Ford Territory TX 2003 Ford Falcon XR8 2009 Territory Turbo Ghia Current: 2012 Audi A4 B8 2.0T Quattro |
15-06-2006, 12:32 AM | #10 | ||
Right Click on Desktop, Properties
Two ways of resetting it; Click on Themes, choose Windows XP then hit Apply OR; Click on Appearance Find "Windows and Buttons" Select the other option in the list, hit apply, then select the original (Windows XP Style) Hit OK and you should be right. You may need to re-apply any wallpapers you had set up Yes, I do this for a living Technical Support is the life for me ;) |
15-06-2006, 02:53 PM | #11 | ||
Cracked Pot
Have you changed your screen resolution?
Open "Display Properties" and click the "Settings" tab
Ford Faithful
15-06-2006, 06:23 PM | #12 | ||
If you just want to enlarge your font and page size, hold down CTRL and tap on + twice, this will give you an easy to read page, to decrease hold CTRL and tap - twice to reduce, this setting will stay on all pages until you close you browser, and then reset.
