25-01-2006, 05:39 PM | #1 | ||
Irregular Member
Look what just happened to my radiator! It just fell apart, lucky I wasn't driving or out in the sticks. It's boody made of plastic, are all new cars like this?
The car only just clicked over 40,000km- ИИИ peice of rubbish. AAAARRRH The tilt tray is on the way Last edited by '63Deluxe; 04-11-2017 at 12:05 PM. |
25-01-2006, 05:54 PM | #2 | ||
cars have had plastic side tanks for years now.
25-01-2006, 06:07 PM | #3 | ||
Boosted TQE FTW
hmmm... late model commy?
Daily Driver: 08' ford ranger Project: EF Falcon Turbo... Not long till back on the road..... |
25-01-2006, 06:17 PM | #4 | ||
looks like a late model commodore... vx/vy. I have broken a radiator tank in the same way removing the radiator hose as it was on FT.
Is that covered under warranty?? |
25-01-2006, 06:47 PM | #5 | ||
Irregular Member
VY II ute.
and I have told them it's under warranty things fixed so far Paint work covered in dull spots within 2 weeks Holden hard lid needed adjustment so it would actually lock New Diff - at 11000 km, clunky coasting along drive axel fell out whilst driving - nice and noisy also made the ABS go beserkried to stop and now the radiator |
25-01-2006, 10:40 PM | #6 | ||
iRegular crossmember
Lemon!!
1996 EF XR6 5 spd manual 2 1/2" manta S/S exhaust After market alpine/soundstream stereo 18" tyhpoons superlows waiting to go in.... spoilerless |
25-01-2006, 11:30 PM | #7 | ||
Pretty much all new cars these days have radiators with plastic tanks, and have had since about the late 80's. I don't see any real benefit in it, apart from lighter weight and possible cheaper production costs.
While the car manufacturers can be blamed to a certain extent, what it all comes down to is the production quality of the third party suppliers. Both Holden and Ford source many compontents from the same suppliers and correct me if I'm wrong, I think radiators is one of them (from Calsonic?), meaning that Falcons aren't exempt from these sorts of problems either. Same with the noisy diff - It is common knowledge that both Falcons and Commodores have dodgy diffs (moreso in the Falcons for some reason) as they sourced from the same supplier (Dana). I suspect this is the main reason for Holden dumping Dana as their diff supplier and contracting ZF to supply units for the VE. |
26-01-2006, 12:29 AM | #8 | ||
cross breeder
Ea's where the first ford with a plastic radiator,and mabey vr on commies?It is fairly common,I cracked a tank n my eb xr8 when it was 8yo,wasn't even trying,and I live in the sticks! :
Like xk-xf's?
http://www.ozfalcon.com.au/ |
26-01-2006, 03:25 PM | #9 | |||
26-01-2006, 04:05 PM | #10 | |||
Force Fed Fords
That radiator hose clamp looks like it is overtightened. Thing with plastic tanks is if you overtighten the hose clamp, you can actually crack the outlet flange which will allow vibration and normal use to accentuate the damage. Had the same thing on a DA. Radiator guy showed me the broken off part had been cracked for a while, and was cause by overtightening. Good news is though, they are not that expensive to fix.
If brains were gasoline, you wouldn't have enough to power an ants go-cart a half a lap around a Cheerio - Ron Shirley Quote:
26-01-2006, 04:56 PM | #11 | ||||
AFF's 1st DM.......
26-01-2006, 05:37 PM | #12 | |||
26-01-2006, 10:55 PM | #13 | ||||
Force Fed Fords
26-01-2006, 10:58 PM | #14 | ||||
Force Fed Fords
