Old 25-09-2021, 11:58 AM   #1
Jjacovou
Default Diff replacement help
So i have an au2 falcon xls manual ute and have a 3.45lsd diff from an xr6 and wanting to change over to an open diff.
Would I have to replace the whole rear end or can i swap the centres over and whats the procedure for that.
Jjacovou is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2021, 04:42 PM   #2
redxm
64 Deluxe 4 door
redxm's Avatar
Default Re: Diff replacement help
Ute is leaf springs. Sedan is coils I assume the XR6 is a sedan?
Diff centres can be swapped but they need to be set up properly with clearances, backlash etc. Not something I'd attempt without help and especially if you've got to ask.
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2021, 06:45 PM   #3
Blue Dog
Question Re: Diff replacement help
Confused, not sure what you're saying...........
I get that you have an AU2 XLS manual ute.
It appears you also have a 3.45LSD out of an XR6.
It sounds like the LSD is installed in the ute, as you want to change over to an open diff.
So what's the question again?
Blue Dog is offline   Reply With Quote Multi-Quote with this Post
Old 25-09-2021, 07:01 PM   #4
Jjacovou
My falcon when i bought it had a 3.45lsd installed and im wanting to swap my diff to an open diff as i have plans on locking it with mini spool. Would i be able to buy a diff centre and install it with the same axles i have now or would I have to buy a whole rear end and drop mine then install that one?
Old 27-09-2021, 07:27 AM   #5
sgj66
If you change the gears over you have to set the backlash to loose it will chatter to tight it will howl like a mongrel dog google setting backlash it will scare you
sgj66 is offline   Reply With Quote Multi-Quote with this Post
Old 27-09-2021, 09:13 AM   #6
mad2
Regular...with metamusal
grab another diff [that suits] & play with that.
