27-10-2007, 03:48 PM | #1 | ||
my au i6 has had a low rpm engine rattle for quite some time now.
it only dose it between 1800/1000 rpm as the revs drop ,if i flutter the revs around 1500rpm i can get it to do it consistantly. it dosen't do it @ idle or any other rpm range. it dose it weather the motors hot or cold. it sounds simalar to bearings rattling but not quite the same more of a slapping/ rattle kind of sound .but it is very noticable ,you can hear it inside the car. i don't think its the HLA's ,because i have had a dud lifters before and it dosn't sound the same.i thought it may be the timing chain but after checking the the tensioner its not that. if it has a worn bearing wouldn't it rattle right through the rpm range? it was suggested to me that the input shaft bearing might be worn also???? or even maybe a dud spigot bearing??? or even a cracked piston??? the car has been having a high speed vibration also ,that goes away once i put my foot on the clutch.maybe that has somethings to do with it. any help appreciated.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
27-10-2007, 04:53 PM | #2 | |||
When you say
If at a stop is it in neutral or is the clutch in?
My Car |
28-10-2007, 09:32 AM | #3 | ||
it dose it while moving or stopped,and with the clutch in or out it still makes the noise.
28-10-2007, 12:14 PM | #4 | ||
Walking with God
It's just the AU rattles. Here's some good discussion about it.
http://www.fordforums.com.au/showthr...hlight=rattles Cheers, GK
28-10-2007, 04:57 PM | #6 | |||
i put a bottle of nulon lifter freeup in it this arvo .when i started it ,it had the same rattle .but after taking it for a bit of a drive,when i got home it wasn't making the rattle anymore.i'l try it again later on a cold start and see what it dose. thanks for your help.
30-10-2007, 11:12 PM | #7 | ||
it still rattles on a cold start,but after its warm its fine.could it just be an oil grade issue???
it did using nulon 10/w30 and penrite 10 w/50. any thoughts?
