Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link |
06-03-2014, 10:48 AM | #1 | |||
The front kit using the 355mm fixed rotors with alloy hat and our Shockworks Mando calliper will be $1800. The floating option with the 355mm disc and callipers is $2000. The callipers come with the low dust street pads. The S1 track pad is an $80 option for the kit. So far we have tested with the standard Ford brake line and will have a braided line available with the kit as an option soon. Prices for the lines are still to be confirmed. I hope this helps!! Cheers Brett |
06-03-2014, 11:45 AM | #2 | |||
So when I've worn out the first set of S1 pads how much to replace them?
2010 mk1 GS sedan with 412rwkw thanks to Pitlane Performance! KPM Street fighter stage 2 intercooler with 70mm pulley 1000cc injectors Herrod Fuel pump BMC air filter Built tailshaft Shockworks Coilovers Shockworks 4 piston monobloc front brake kit Herrod oil breather and "special" diff breather kit 19x9.5 rears 19x8.5 fronts with sticky Michelin rubber |
