Old 01-07-2017, 07:50 PM   #1
NCII40
XR6T BA 2002
NCII40's Avatar
Default VSS Bypass* Corrected Trans Schedule* Success *
All Thanks, Donations and Support to Shift Kits Australia for their Assistance
Installing 3.7, 3.9, 4.11 to AU will throw your speedometer out
Installing a Correcter behind the cluster to adjust the speedometer back into real time will result in your transmission shifting incorrectly across the board and Torque lock up
Below is a wiring diagram on how to successfully correct the issue
My Trans is shifting correctly again
Cut the White VSS wire out of the transmission
Rejoin and solder on correct gauge wire and shrink over to ensure its sealed from weather
Run new wire up into the engine bay and feed through ECU loom bung
Remove Glove box and you should see the wire coming out
Neatly run down into the ECU loom plug
Cut white wire into 58 pin and safely terminate cluster feed in, ( leave enough length out of ECU plug to solder in new feed and to later return to stock )
Rejoin and solder new feed with one end of a 1K resistor to the wire out of the ECU loom now directly feeding pin 58 on ECU from VSS, Shrink over to keep neat and safe
Cut Red wire feeding pin 71, Rejoin with the other side of the 1K resistor. Solder and shrink over for safety and protection
Can supply photos, but would rather do it again on my car as i can neaten things up more to help demonstrate professionalism
XR6T 2002 BA
NCII40 is online now   Reply With Quote Multi-Quote with this Post
Old 26-05-2020, 11:40 AM   #2
mad2
Regular...with metamusal
Default Re: VSS Bypass* Corrected Trans Schedule* Success *
pic is no longer available
mad2 is online now   Reply With Quote Multi-Quote with this Post
Old 26-05-2020, 11:05 PM   #3
NCII40
XR6T BA 2002
NCII40's Avatar
XR6T 2002 BA
Old 23-11-2021, 04:06 PM   #4
Climaxxx
Originally Posted by NCII40 View Post
Hi Mate
Are you still on here???
Climaxxx is offline   Reply With Quote Multi-Quote with this Post
Old 30-11-2021, 09:54 PM   #5
NCII40
XR6T BA 2002
NCII40's Avatar
Originally Posted by Climaxxx View Post
Hi Mate
Yer mate just your saw your PM
Il write back you here, best i can to help
Hi Mate
I have 3.73 diff gears put in. Instant whine i thought was from gears but i think it's the trans, now after trans stuffed the bearings and a rebuild. A speedo corrector was installed at the ECU. The whine is still there with correct speed showing and the torque converter is still not locking up. It keeps hunting like it did before.I would og thought the trans people would of callibtated the car etc. Can you please help???
Thanks
Shane
Sorry for the delay
Sold the au so hard to get ya pics
Il explain best i can
Post photos here, and il show you how to do it
You need post photos here of the
3 wires running to transducer under car
inside engine bay, passenger side firewall where all the wires run through bung
Behind the glovebox
Behind the passenger side kickpanel
ECU
ECU plug
You will need to run a wire from the transducer
Under the car, passenger side of the gearbox,
Look for the 3 wires running up to the top, back of the box
You will need to find the white wire here, just strip a little plastic off, (do not cut it, no need ) too expose some copper
grab 4 metres of some 12 or 14 gauge wire and solder on
Run that wire, up into the firewall on the passenger side, you see a black bung on the firewall with a heap of wires going into it, thread that wire in with the others,
go into the car, remove the glovebox and you will see all those wires and your new wire coming through the bung
remove the kick panel on the passenger side to expose the ECU,
Drill out the rivett and remove ecu out enough to unplug, there is a screw on top on the plug that holds it to the ecu, so unscrew it first
Grab the ecu plug and look for pin 58, loosen up that wire,( its a white wire ), loosen it from the bundle and cut it 100mm to 200mm back from plug,
Join your new wire from transducer in this pin 58 wire on the plug, so now you have a direct line from transducer straight to pin 58
Tape and cap off the other end of the white wire you cut, it comes from elsewhere, and no longer required
Now look for pin 71, its a red wire
Strip back a bit of plastic and solder on 1 side of 1k ohm resistor to it,
Then on the other end of the resistor, solder than on to you pin 58 wire , preferably where you just did that new join
Hope my drawing helps
If not post pics and il help from the pics
XR6T 2002 BA
Old 30-11-2021, 10:01 PM   #6
NCII40
XR6T BA 2002
NCII40's Avatar
Your speedo corrector should be behind the cluster, to alter the current draw in out of the vss wire
You will need a continental ratio box, i have 1 spare here if you need it
XR6T 2002 BA
Old 13-02-2022, 03:04 PM   #7
NCII40
XR6T BA 2002
NCII40's Avatar
Ratio box has been sold
Here are some updated pics on how to connect the ratio box behind the cluster into the DIN
XR6T 2002 BA
Old 27-08-2022, 01:45 PM   #8
Mighty_Windsor
I need to try this. Will this help me bypass speedo telling trans to shift
Mighty_Windsor is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2022, 01:03 PM   #9
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Send him a PM
Old 18-09-2022, 09:16 AM   #10
Mighty_Windsor
This has not worked for me i guess. Not having the ABS sensor plugged in and no ABS fuse is partly why
Thread Tools
Display Modes
