Hi people, as you may have guessed, I am trying to find out what the fastest unopened e-series car is, and also the most powerful.
The reason behind the query is that I intend on building an unregistered thrash car (all mods will eventually be transferred to the road car though...) from an EB, and I want it to be a development car (for said road car). The car is an EBI Auto, base model. The plan (in order of installation) is: 1. (Locked) 3.7/3.9/4.1 diff gears 2. Manualised Auto 3. Extractors, cat, and not much else exhaust 4. Six throttle bodies (undecided on slide/butterfly yet) 5. Manual Trans 6. Port/Polish 7. Cam/Computer combination. 8. High Compression/Forced induction. I would like to know about what kind of power and 1/4 mile I will be getting by step 4/5, and what else I can do to help power/times that doesnt involve internal mods. And again, what is the current record for unopened (n/a) eseries, in both 1/4 mile time and outright power? thanks Ben *yeah, i have too many ideas floating around in my head... |
![]() Join Date: Dec 2004
For an unopened I6 you'll want a manual so that more power is placed on the road. A port and polish would require "opening" the motor too ;) Same goes with getting a cam, or increasing the compression by means of piston change or shaving the head.
Boost Addict
not e series, but AU
mods: Full exhaust, POD, S3 Au cam, ported, stock ecu, manual, LSD: 14.9 @ 94mph 150kW at wheels building an ef S2 wagon atm so far i got full exhaust and CAI, K&N panel filter, shift kitted 128kW at wheels going to quater mile this saturday next week Crow S2 cam, adjustable vernier gear, ECU adjustments
N12 Pulsar - sold Gen1 Liberty Turbo - sold VP Commodore Turbo - sold LN65 Hilux Turbo - sold EL31 Corolla Turbo - sold Ford AU Ute Turbo - sold Ford AU XR8 Sedan - 5.4l V8 Turbo (in the build) Ford BA XR6T Ute - daily driver Ford FG XR6T Sedan - cruiser do you see a general trend? I DO ![]() Can't live with it, can't live without it! |
#4 | |||
Boost Addict
yeah, but the plan is to have the record before the commencement of step 6. After that you start to spend real money on the engine...
Leave the unopened/opened BS to the boss motors and LS1's IMO.
Its all a huge ****.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi. |
#7 | |||
I'll go back to my pushrod wheezer now ![]() |
#8 | |||
yeah, but this whole project is about proving how good the 4L OHC engines are in a bang-for-your-buck way, and having a fast, unopened, car is one of the steps along that path. And I'm up for all the titles I can get my hands on (like everyone really) cya Ben |
Custom user title
THere isnt a such thing as an un-opened eseries... THey have all had 1-20 head gaskets by now... so who knows whats going on any more...
#10 | |||
#11 | |||
and does an engine swap count as an internally modified engine? If it doesn't I should put AU engine as step 6... |
#12 | |||
Riding The Lightning
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA |
#13 | |||
Mine has done a 14.8 @ 95mph un-opened.
02 BA XR6 T U R B O Venom Red, Auto 13.97 @ 101mph Quote:
#14 | |||
#15 | ||||
#16 | ||
Oops, I slipped....
If you can see oil galleries/passages, the engine is classed as open. Windsor lower manifold and I6 camshaft are both in this class.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
#17 | ||||
#18 | ||
Oops, I slipped....
Unopened motors are for lazy people and dumbarses anyway :P
#19 | |||
Boost Addict
there are a few AU 6s out there that havent had their HG change yet as they are below the 180 mark. i believe u can run very well into the 14s with an "unopened" engine, you can substitute the port job for a good ecu retune, i was targeting 14s on stock ecu, however was running redicolously rich, much more power to be gained by a decent retune. i rekon a mid 14 sec pass would have been very well on teh cards with an aftermarket ecu or similar i am hopeing for a 14sec pass in the ef wagon without pulling the head off, having said that HG was changed by previous owner
#20 | |||
![]() Join Date: Jan 2005
Just go nuts and get internal work done as well, then say it's unopened, who's gonna pull it apart to find out? :P
BTW I agree with Dan Quote:
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH |
#21 | |||
Last warning
Ported?? as in ported head? thats classed as opened as far as i'm aware. i'd say high 14's would be the bench mark for an unopened I6. no one really tries though because a cam cahnge is such an easy and cheap mod. cam's are generally done before ECU/diff gears.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#22 | |||
Boost Addict
that is correct, ported head, hence i said in a later post that you could substitute the ported head for an aftermarket ecu and still target similar or better figures/numbers
#23 | ||
Last warning
ah fair enough, same aims
#24 | ||
Driftin shopping trolleys
i got a 15.29 out of my el with only a cat back
VZ Calais 5.7ltr cammed, stalled, and the rest. 04 BA XR6T ute |
#25 | ||
IMO, unopened is a bit of a w*nk.
If you truely want to run the numbers "unopened" you will need an eb xr6 manual. You need the biggest factory cam so the engine remains unopened. Install lower diff gears, good flowing extractors and exhaust, custom inlet, CAI, good fuel and an edit. It also helps to take as much crap out as possible, lighter seats etc Chrispy |
#26 | ||
Tuned @ Pitlane Frankston
Speed = Money = Wasted on an e-series.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
#27 | ||
I'd like to see an award for the most longwinded title/tenuous grip on a record unopened title.
Eg. Fastest BA2 manual unopened BOSS with catback, underdrives and Filter/CAI but without EDIT or headers. Top that! |
#28 | |||
Shoot.
20V Turbo |
#29 | |||
Last warning
#30 | ||
Money spent on mods is wasted on any car. Captain obvious FTW!
If anything I'd rather spend it on a cheaper car like an E-series, at least if you write it off you can reshell it and put your driveline back in for cheap. |
