14-01-2006, 06:19 PM | #1 | ||
Hi,
I've just replaced the radiator on a manual '89 Laser KE. On the bottom of the old radiator near the drain stopcoc.k is a fairly large bolt. It looks like there used to be 2 wires that fit into the bolt but they've been yanked out. I've put the old bolt into the new radiator but I'd like to know what its actually there for and what should be connected to it. The temperature gauge inside the car is working fine, the fan is kicking in when required so I'm guessing it might just be some kind of warning light or something. The car seems to run perfectly fine without it but I'd still like to find out if it should be repaired or not. If anyone can shed some light I'd appreciate it. Cheers, Kev |
15-01-2006, 01:01 AM | #2 | ||
What a performer!
Not really sure what bolt you're talking about mate. If you can get a picture, I can compare it to one of my two KE's i've got.
1981 Ford Laser KA :: E5 :: 2002-2003 1989 Ford Laser KE TX3 :: BP :: 2003-2007 75fwkW 1990 Ford Laser KF TX3 :: BP :: 2010-2011 1991 Ford Laser KF TX3 :: BP-T :: 2011-2015 109fwkW 2007 Ford Falcon BF XR6 Turbo Ute :: Barra 245T :: 2014-2019 324rwkW 1998 Ford Falcon AU XR8 Ute :: Windsor V8 :: 2019-2020 2008 Ford Fiesta XR4 :: Duratec 150 :: 2021-* 1998 Ford Falcon AU XR6 :: HP Intech :: 2021-* |
15-01-2006, 11:20 PM | #3 | ||
no probs, have got some pictures.
Rad1 is the old radiator. The bolt fits in the big round hole in the bottom of the radiator (second hole from the left) Rad 2 Is a picture of the installed bolt Rad3 is the connector that should be fitted to the bolt cheers for having a look |
