18-02-2021, 01:32 PM | #1 | ||
I think these are transmission codes
18-02-2021, 06:04 PM | #2 | ||
Check for a loose earth on the LH chassis rail just under the air cleaner. If you can rotate the eyelet, then its a possibility its a bad earth and can cause the two codes you are referring to.
Could also be attributed to EGR and MAP sensor issues. |
18-02-2021, 11:43 PM | #3 | ||
I will start by pulling out the egg valve assembly. Thanks for your help.
19-02-2021, 04:49 PM | #4 | ||
Blanked off EGR and took it for a 50km run. No codes. New EGR with cooler $724 from Ford!
Thread Tools | |
Display Modes | |
