Old 04-09-2020, 02:13 AM   #1
strrb
Default Borg Warner diffs TC, TD, TE & TF
I have a TF 4cyl 2.0 ltr diff (small type). It has a U bolt drive coupling. I hope to be able to swap this to a flange coupling from a TE large type diff. Can anyone tell me if the input shaft spline is the same size.
Thnx in advance, Roy
strrb is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2020, 04:02 PM   #2
strrb
Default Re: Borg Warner diffs TC, TD, TE & TF 4 cyl 2.0 ltr 8 bolt diff
[QUOTE=strrb;6487266]I have a TF 4cyl 2.0 ltr diff (small type). It has a U bolt drive coupling. I hope to be able to swap this to a flange coupling to suit my tailshaft. Can anyone tell me if the input shaft spline is the same size.
Old 06-09-2020, 05:31 PM   #3
redxm
64 Deluxe 4 door
redxm's Avatar
I know TC/TD pinion splines are the same as I did a swap years ago in my old sports sedan.
I'd reckon it would be close.
Bear in mind crush tube etc
XM Deluxe
FG XR50
BA Pursuit Ute
redxm is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2020, 02:01 AM   #4
strrb
Thnx for the reply & info, it is very helpful & reassuring.
Roy
