29-06-2011, 12:28 PM | #1 | ||
I changed the battery the other day, now it seems to be idling lower than it used to, will it come good or will I have to adjust. cars done about 20klm since battery changs over.
Baz |
29-06-2011, 10:36 PM | #2 | ||
baz is yours an auto or a manual?? Either way though it shouldn't be doing it. Check for any vacuum leaks and take it from there.
Owning a Cougar is like owning a Super Model Good to own but "High Maintenance" 2000 Model Eibach Cougar (Auto) - Now dead & buried |
30-06-2011, 05:40 PM | #3 | ||
Its a manual. it might have been just a one off, I will be driving it again tomorrow so keeping fingers crossed.
01-07-2011, 04:23 PM | #4 | ||
I got stuck at a road workes for a long time today, seems like it fixed the computer memory, so if you change your battery let it idle for a long time.
Well I hope that was what fixed it. |
02-07-2011, 05:01 PM | #5 | ||
Update, letting it idle for a few minutes brought it back to normal.
would attaching jumper leads from a donor battery to the terminals before removing dead battery keep all the memory? |
03-07-2011, 09:33 PM | #6 | ||
Baz is it running OK now ?? When you disconnect the battery it does take a while for the ECU to adjust again. The best thing I have found is to take it for a half hour run on the freeway (in my case the M5) and this usually sorts it out and everything will be back to normal.
04-07-2011, 10:11 AM | #7 | ||
Yes its back to normal now, letting it idle at the road works for about 3 minutes fixed the problem.
I think the jumper lead idea might be the way to go though. |
