20-08-2022, 08:59 PM | #1 | ||
Hi there, newbie here. First time Ford owner as well. Have a MY21 Focus Active with the Safety Pack.
Recently my Ford Pass keeps notifying me more frequently now that it is in deep sleep mode so no remote features can be done via the app. It also says to drive so the feature will be reactivated. It will be reactivated and it will deactivate again after a few hours. Before even if I don't drive the car for days it remains active. Also, my start stop feature is not turning on as before. Bought the car in November 2021 as a demo but the car was registered on March 2021. Just had the car recently serviced and the Recall (22S21) for the oil separator done as well and as per Dealer everything is all good. Just updated to Sync 4 as well. Everything in the car works great once driving but just getting annoyed with the frequent notification of the deep sleep mode. I have two cars and sometimes I don't the drive the Ford for days but never had the issue before. Is my battery on the way out? Will a trickle charger help when I don't drive the car? Thanks |
21-08-2022, 12:41 PM | #2 | ||
Correction re Ford Sync: updated to 3.4 and not 4
21-08-2022, 07:01 PM | #3 | ||
I have a 19.75 Active and it will not use stop start when the battery is a bit low in charge.
Will see if a recall is needed on mine, Ford service this week. |
09-11-2022, 02:18 PM | #4 | ||
Get your car batteries checked. Maybe they had been run flat once or twice before you owned the vehicles.
I've got an MY20 Focus ST-Line Wagon and my start stop works fine, the battery is putting out 14-14.8v. Start stop can put unnecessary drain on the battery so it makes sense for the ECU to disable anything using excess power. That includes TCU (FordPass Modem). MY21-onward Focus have FordPass, so the OP wouldn't be having that issue. |
09-11-2022, 07:14 PM | #5 | ||
I have the same car also with the safety pack.
It, too, does the same thing and so I took it to the dealer who kept it for 2 days and returned it saying couldn't fault it and they had ' run out of warranty money and won't be doing anything more as everything was working as intended'. Clearly it's not. I believe my battery voltage is 14.5v whilst using which, I believe, renders the auto stop/start inoperative. I have a trickle charger and after disconnecting it and starting the car voltage is 14.8v. However, within 30 minutes or so voltage drops to 14.5 and stop/start doesn't work. Within a day or so after trickle charging I again get the message that the car is in deep sleep mode. This means the car can't be started remotely. the passenger's door handle won't unlock/lock the car and now lane guidance has disappeared from the instrument cluster and is inoperative. Also the radio shuts down immediately and can't be turned on manually if the engine isn't running. And so, I've contacted FoMoCo and was advised to take it to another dealer and given a reference number which I have to quote back to Ford (not the dealer) on the day it's in the workshop. 12 months ago I had the above issues and they replaced the battery and the problem went away. I'm not advocating a battery change as I believe it's a BMS issue which can't be deactivated like you can in the Ranger. Because this dealer is over the other side of town I need a loan car. I have to pay $50/day for the free loan car to waive the insurance excess. It's booked in for Friday 18th. |
09-11-2022, 09:28 PM | #6 | ||
I had the battery issue and the start-stop not working.
The wrong battery was selected in the Body Control Module, it did not match the factory battery Ford installed so it was a production process error in the module software configuration. After changing the selected battery to the one actually in the car the start-stop works everyday for more than a month now. Deep sleep mode can be disabled on the APIM (module that contains Sync) but if you resolve the battery issue above then it should also resolve your Sync going in to deep sleep. You will need an OBD adapter and a licensed copy of Forscan. Happy to help as the issue drove me nuts for a while as I would charge the battery and start-stop would work only for a day or two and back again not working.
2020.25 Focus SA ST-Line Wagon + DAP 2011 Focus LW Trend (Diesel) [sold] 2006 Territory SY Ghia (AWD) |
09-11-2022, 11:56 PM | #7 | ||
