Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Early Falcon Car Club of Qld Inc
Early Falcon Car Club of Qld Inc The Queensland early model Falcon Club.
Old 23-02-2024, 12:38 AM   #1
GTXB1969
Default Resistor wire
Hello fellow XB Owners I NEED HELP Installing a electronic Dizzy into my 351 Cleveland WHER is the resistor wire? I know it runs from Coil to ignition but I need to find where to connect a nEW WIRE to run to Positive on Coil Colur location need help please
GTXB1969 is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2024, 09:35 AM   #2
xwboss
xwboss's Avatar
Default Re: Resistor wire
The wire resistor to the coil is in the harness. If you unwrap the harness from the coil back towards the firewall you will see it.
It is a thick pink wire if you keep following it back you will get to a red/green (From memory) you need to run a new wire from that point.
Territory black VSI lpg
XW GS Fairmont 351C toploader 9inch
Mazda Bravo 4 X 4
xwboss is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2024, 01:15 PM   #3
GTXB1969
Hi mate some advice say its a red/purple wire from ignition which Ive found followed it back through firewall above brake booster then to junction near battery it seems to go on past battery and not to coil I note on coil positive side are 2 brown wires one thicker than the other so thinking is the thin brown wire the resistor wire so now about to solve that destination of the 2 brown hoping one connects to the red/purple damn am ove r it bloody ford engineers
Old 23-02-2024, 03:31 PM   #4
cs123
cs123's Avatar
The other wire is probably going to the starter solenoid.
I love Holdens....
cs123 is online now   Reply With Quote Multi-Quote with this Post
