Old 30-06-2010, 01:23 PM   #1
robbyj
Rob
robbyj's Avatar
Default Breaks still squeeking??
I had my front pads changed a while ago.. and as per expected the noise under breaking while the pads are wearing in started.. but has never gone.
Its been roughly 15-20,000 ks and they still do it.
Are the pads not bedded properly? Is there any other reasons while they would still be making this squeeking noise.
If i drive as nice and easy it wont do it, as soon as i go a little bit harder.. warm or cold.. it does it. Any ideas?
Supercharged Nissan 350z 280rwkw
Blueprint series 3 AU V8 manual
robbyj is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2010, 02:05 PM   #2
Dave_Obsession
Resident AFF detailer
Dave_Obsession's Avatar
If you've done 15-20,000kms on them, they're well and truly bedded in....
Have you tried spraying them with some of that stop-squeal stuff??
What condition are your rotors in??? Do they need machining or replacing???
Old 30-06-2010, 02:28 PM   #3
ratter
ratter's Avatar
What sort of pads are you using? some are just noisey
Pit Lane Performance
Old 30-06-2010, 09:25 PM   #4
robbyj
Rob
robbyj's Avatar
they are bendix pads. I have new RDA slotted rotors to put on when i get some free time. So the normal stock ones. As far as i know/can see the rotors are fine.
Might try some spray stuff.
Old 30-06-2010, 09:58 PM   #5
ratter
ratter's Avatar
Which Bendix?
where your rotors machined when the new pads went on?
Old 30-06-2010, 10:02 PM   #6
robbyj
Rob
robbyj's Avatar
not sure, and i doubt it.
Old 30-06-2010, 10:15 PM   #7
kruptor
Custom Member
I find using black grease,use abit of grease at the edges of the brake pad back plate which contacts the brake calliper/calliper plates.When it slide doesnt create a noise or vibration...You will understand when you slide the pad in and out of the calliper so you will know where to lube the brake pad back.
kruptor is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2010, 10:43 PM   #8
Ducati888
BRAKES FFS not breaks
"You can't fight stupid people - there's just too many of them"
Ducati888 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2010, 06:46 PM   #9
Auturbo6
The only thing u'll see!!
Auturbo6's Avatar
I find puting black grease on the friction face makes the pads last so much longer.
Auturbo6 is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2010, 07:23 PM   #10
AUIIPURSUIT
pursuit ute baby
AUIIPURSUIT's Avatar
yea, massive saver on pads, and youll have a panel beater for a best friend too if youre lonely !!
AUIIPURSUIT is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2010, 08:21 PM   #11
KURS3D
KURS3D
KURS3D's Avatar
lol lucky auturbo6 works with one
do u get it? no. ok let me speak moron for a minute
KURS3D is offline   Reply With Quote Multi-Quote with this Post
