Old 25-06-2020, 10:37 AM   #1
sednwol
sednwol's Avatar
Default Whining noise
Just had a leaking steering rack in my S3 XR8 replaced and now I have a whining noise, more noticeable when turning but still noticeable when driving in a straight line. I will give the mechanic a call but would appreciate your input before I do.
sednwol is offline   Reply With Quote Multi-Quote with this Post
Old 25-06-2020, 09:05 PM   #2
XC50077
Drive'n Cruise'n Live'n
XC50077's Avatar
Default Re: Whining noise
Did they use the correct Ford type Formula F P/S fluid. Cheers
XC50077 is offline   Reply With Quote Multi-Quote with this Post
Old 26-06-2020, 12:40 PM   #3
T3rminator
T3rminator's Avatar
Did they bleed the air out? Take the cap off and do several full locks on the steering wheel.
T3rminator is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2020, 08:11 PM   #4
George V
If a mechanic replaced your steering rack, you would expect them to bleed the system.
Did you ever run out of PS oil?
If so, may need a new pump.
Regards,
George V
George V is offline   Reply With Quote Multi-Quote with this Post
Old 25-07-2020, 07:21 PM   #5
Crazy Dazz
I used to notice a lot of whining in the AUs
Even my Territory had a similar whine.
Then she left, and its been quiet ever since.
Time to Make the Hippies Cry Again
