25-04-2007, 03:16 PM | #1 | ||
hey, trying to fit my xr cluster. need to replace the oil warning sender with an oil pressure sender, but where on the 6's is this located?
Thanks, Brendan |
25-04-2007, 03:32 PM | #2 | ||
on the block under the intake manifold
25-04-2007, 03:37 PM | #3 | ||
easy to get to?
25-04-2007, 03:38 PM | #4 | ||
it's near the coil pack, on a forte it is just a little bolt type thing with 1 wire hanging out of it
yes easy to get to, ill put a couple of pics up in a minute |
25-04-2007, 03:43 PM | #5 | ||
cheers
25-04-2007, 03:47 PM | #6 | ||
here you go
easiest way, take off the intake snorkel, straight in there then |
25-04-2007, 03:49 PM | #7 | ||
that looks the same as the oil pressure sender I bought today, do they look different? how can you tell them apart?
25-04-2007, 03:53 PM | #8 | ||
the actual sender for the dash gauge, well on my old ea anyway, was a big bulbous thing, about 3 times the size of that
25-04-2007, 03:53 PM | #9 | ||
horsepower
i am pretty sure you will need a the doc. from aufalcon on changing std to xr type clusters, as the wiring is a little diffrent ???
25-04-2007, 03:57 PM | #10 | ||
this gives you an idea about the difference between how the 2 units work
http://www.siemensvdo.com/products_s...umentation.htm do you know what the part number is? these are from the parts database ASW 102 SWITCH OIL PRESS, WITH OIL LIGHT $9.45 EF 9D290 A SWITCH ASSY - OIL PRESSURE, WITH OIL GUAGE $46.00 |
25-04-2007, 03:59 PM | #11 | ||
yeah, I know the wiring is diff, thats all sorted
25-04-2007, 04:04 PM | #12 | ||
don't know the part number, but on the pack it said oil pressure sender. But it cost less the $10. must be wrong
25-04-2007, 04:09 PM | #13 | ||
probably, one of them is a switch, the other is a sender, where did you get it from?
25-04-2007, 04:15 PM | #14 | ||
Walking with God
I'm also interested in all this info.
Cheers for the pics! GK
25-04-2007, 04:45 PM | #15 | |||
25-04-2007, 05:23 PM | #16 | ||
it was a switch. On the pack it said sender, and on the back it said it suits au falcons, fairlane and fairmonts. Which fairlane uses a switch?? Anyway can't get a sender in town today, do I need to run any extra wires when I hook it up?
25-04-2007, 07:20 PM | #17 | ||
you shouldn't have to run any extra wires, not sure if au's are different, but ea's only had one wire with a gauge
25-04-2007, 07:57 PM | #18 | ||
Flying high...
they are a b***h to get at, u need a 1'' deep socket to remove it. no spanners can get at it as there is limited room.
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel, 3" mandrel intake, K&N pod in the box, Polished Rocker Cover. |
25-04-2007, 10:09 PM | #19 | ||
mate i just put an xr6 engine in my au .i'm having the oposite problem to you .my ecu won't read the pressure gauge sender thats in it .so i have to swap it with the switch style one as in the pics above ,that came on my original motor.
the xr6 one is about 3 times as long as the one in the pics above and its white and its also needs a bigger diameter spanner/sparkplug style socket to undo.its not an easy job.
au2 s i6 5 spd , au series 1 xr6 hp motor, cam advanced 5*,jmm cai ,topgun leads,pacey 4480's,3 inch cat,lukey 2 1/2 sports zorst and 3.89 lsd,standard ecu. current best,14.939 @ 93.17. |
25-04-2007, 10:15 PM | #20 | ||
Guys, remember that AU 1s came with proper, functioning gauges, whereas series 2+ got a dogdy guage, so you may find that series one Fortes use a switch, and series one XRs use a sender, but all series 2+ just use the switch.
Apparently in series 2 (can any series 2 owners confirm this), the gauge sweeps straight up to the 7 mark, and it's either there, or at 0, there is no in between, whereas series 1 sweeps back and forth just like a fuel gauge (I know from experience when my oil pressure was all over the shop).
25-04-2007, 10:29 PM | #21 | ||
i should have said , i put a series 1 xr6 motor in a series 2 .the actual swithes/senors are heaps different.they both use the same style plug/clip though.
25-04-2007, 11:20 PM | #22 | |||
The gauge always reads about 3/4, I would assume if the gauge worked properly it would always read full with a switch installed not at 3/4 |
25-04-2007, 11:31 PM | #23 | ||
Mine used to read at 3/4 - around 7 (psi, I think). I think only the AU 1 XRs got the proper sender, everything else appears to be a switch only.
26-04-2007, 03:11 AM | #24 | ||
Good thing I will be getting myself a proper oil pressure gauge then ... will get myself a T-piece adaptor from Pirtek and run the factory switch and the aftermarket sender unit as well.
It's a PITA job too ... there's bugger all room ... either get to it from underneath ... or remove your entire intake and try and reach down through the side ... either way ... swearing is involved.
27-04-2007, 08:44 PM | #25 | ||
Walking with God
Hi Guys,
Just want to confirm that part number for the Oil Pressure Switch as I just got mine today for $50 from Harrison Ford in Melton. EF 9D290 A I'll also confirm that the oil sender is heaps longer (black portion after the octagonal screw) than the oil switch. At least two times longer, perhaps 2 and a half times. If my internet hadn't been speed limited, I'd have posted a piccie. Incidently, the torque setting for the switch/sender on both I6's and 8's is 20Nm. Just waiting on the new cluster from NSW, should be here Tuesday I reckon, a few pin changes, pressure switch install and voila, Tickford dash up and running baby! Yes, ok you can all tell I'm more than a little excited! This is a mod I've wanted to do to the wagon for a long time now. Not long to wait now. Hopefully the pin changes will be easy enough, thanks to the doc from FordMods. Cheers all. GK
2009 Mondeo Zetec TDCi - Moondust Silver 2015 Kia Sorento Platinum - Snow White Pearl 2001 Ducati Monster 900Sie - Red Now gone! 1999 AU1 Futura Wagon - Sparkling Burgundy On LPG Want a Full Life? John 10:10 Last edited by GK; 27-04-2007 at 08:49 PM. |
28-04-2007, 06:15 PM | #26 | ||
Walking with God
I used my neighbour's computer to upload this pic today.
Oil Pressure Sender If you compare it to the oil switch pics earlier in the thread, you can see the considerable size difference! Cheers, GK
16-03-2019, 09:48 AM | #27 | ||
Studzy
Yes that is correct, my xr8 series 1 oil gauge does exactly as mentioned, swings back and forth like a fuel gauge.
But in saying that, it usually sits around the 7 mark on the gauge itself when running around town.
67 XR V8 Falcon - tru xr8 99 XR8 baby brother |
10-04-2019, 02:13 PM | #28 | ||
Wow ... 12 year thread mine .... that's epic indeed.
20-04-2019, 06:33 PM | #30 | ||
Ford T3 Partsologist
I would think that’s for a EF/EL set up, AU uses a ASW102 I6 and V8
2002 Blueprint T3 TE50 Manual Koni Suspension # 161 T-Series Club of Australia - www.tseriesclub.org |
