Old 28-09-2024, 09:56 AM   #1
AlCan
Crazy Mondeo Fan
Default 2013 TDCi Engine Temperature Varying
Hi Guys,
Just back from the cold NZ south, and have really noticed the "dreaded" overcooling problem on my 2013 TDCi. This problem is discussed in various places around the net, mainly relating to MB / DW10B engines, but doesn't seem to appear here. And I can't find the answers I need, anywhere. There is another thread here about engine temps, but it doesn't mention the oil thermostat.
Basically (as typical) the engine is slow to heat up, especially in cold weather, then varies all over the place, below normal temp.
In cool weather, the temperature struggles to get over 70 degrees - i.e the first line after the 60° line. If the engine is working hard, it will get up to normal temperature, just shy of the middle, vertical line, but as soon as it's at reduced load, the temperature drops back again. I know this is normal during a long downhill but not for ordinary highway driving. This doesn't happen on the 2011 TDCi, and sounds exactly like the oil cooler thermostat problem discussed on Talkford and elsewhere.
Do the DW10C engines even have an oil thermostat?
The 2011 is also a DW10C but has hydraulic Power Steering, whereas the 2013 is electric. Can't imagine that has anything to do with it, but as above, the 2011 engine temperature remains almost rock steady once it's warmed up. So, there's something different.
I've searched the net for oil thermostats and only found them for engines up to 2008. P/N 1128018. Looks just like a baby, old-style radiator thermostat housing, but skinnier. Can't find anything for later models. The DW10B oil thermostat appears to live on the front(?) centre of the engine, about where the 10C EGR valve is, but I can't see much else in that area.
Can anyone throw any light on this, please?
AlCan is offline   Reply With Quote Multi-Quote with this Post
Old 28-09-2024, 07:25 PM   #2
AlCan
Crazy Mondeo Fan
Default Re: 2013 TDCi Engine Temperature Varying
I'm hoping someone has a Parts Diagram and can put this question to bed, but in the meantime, I've done a bit more research and some thinking about this.
The Engine Oil Cooler is in fact an Oil<->Water Heat Exchanger, located below the Engine Oil Filter Housing on the lower front of the engine. The Housing seems to bolt to the Heat Exchanger or vice versa, and it's very compact and hard to see what's going on. There seems to be a (coolant?) pipe coming out of the block below the intake manifold and heading down, which probably feeds the Heat Exchanger but there was no visibility on the black and grimy wrecker's yard engine I looked at.
Anyway, it's rare that things are improved by removing parts but this might be just such a case. If the coolant feed to the Heat Exchanger is continuous (no separate thermostat as on 10B engines) and comes hot from the engine BEFORE (i.e upstream, inner side of, i.e. the water pump output side of) the Main Coolant Thermostat, then it could serve a dual function.
When the oil is cold, it could actually heat the oil to near Engine Coolant Temperature (about 80°C), which is almost ideal, while when the oil is over 80°, it would pass heat to the coolant, bringing its temperature down closer to 80°. All temperature control would thus be achieved by the single Coolant Thermostat in its housing at the flywheel end of the head. This would also help explain why these engines seem to take so long to warm up, as they also have to heat up 5.5 litres of oil before the engine will get to thermostat opening temperature.
I don't know if this is how it works but it makes sense to me. Could even call it an elegant design...
If so, would mean the problem must be with the Coolant Thermostat itself, which must be not closing fully or has a faulty seal so that coolant is bypassing it. It looks like a bit of a job to change, but not that bad. Probably much easier than pulling the Oil Filter/Heat Exchanger out - if there's even a thermostat there somewhere.
So, my next question is, what coolant is recommended here, please?
Old 28-09-2024, 09:06 PM   #3
This? https://www.youtube.com/watch?v=iZTadyzsrxE
Old 29-09-2024, 07:16 AM   #4
Peter B - CV8
All those symptoms indicate a coolant thermostat problem to me ie stuck open.
Peter B - CV8 is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2024, 08:15 AM   #5
AlCan
Crazy Mondeo Fan
Thanks Blue! Who would have guessed that? Still makes no sense to me, but I will definitely check it out / try it and let everyone know.
If it works, then I'll have to figure out why... I believe the EGR valve is open at idle (with the engine cover off you can see that the EGR pushrod position has moved), but I don't understand why it would cause the engine to cool that much if it's stuck / dirty / not opening or whatever the problem is.
Seems to me, the EGR valve is the car owner's worst enemy, the carmaker's friend and the mechanics nemesis! So many things to so many people and the cause of so many completely weird problems.
I still don't understand why Exhaust Gas Recirculation is actually beneficial. It reduces the amount of available Oxygen which supposedly reduces the amount of NOx created, but surely, it also increases the amount of incomplete combustion leading to (even more) soot and other partially burnt fuel products, which I imagine are worse for health than NOx. We need Nitrous Oxide in our bloodstream to dilate blood vessels and control Blood Pressure... Can anyone tell me why EGR is good?
I know the stink (Cooked meat in the Alan Howat video) from partially burnt fuel when there's a blown copper washer injector seal - which was bad enough to make a couple of people I know feel sick and refuse to ride in the ('11) car, but that's all sorted now. Though, a component of that unburnt fuel still lingers in the car - can smell it when you first open the door after sitting awhile. The '13 has it too, though that must have all happened before I bought it.
Anyway, the car is still down south as I flew back this trip and won't get back to it until mid-October. Will update then. Thanks again.
Old 29-09-2024, 08:36 AM   #6
AlCan
Crazy Mondeo Fan
Thanks too, Peter B,
I totally agree. It sounds exactly like a bypassing thermostat - I even went and bought a new thermostat assembly. Just haven't had the time / opportunity to fit it yet.
But then I did more reading, and am learning that with these cars, things are too often not what they seem.
(For example, even a mechanic said that the blown injector seal was due to a rocker cover gasket leak, dripping oil onto the manifold. I couldn't see / believe that, but it still took me 5,000km+ to figure out what it really was.)
From the net, it sounds like the oil thermostat can also be a hidden problem that swapping the coolant stat won't fix, so I wanted to try and see which it was first. But since there (now) doesn't appear to be an oil stat in the 10C engine, it can't be that. However, with the addition of the EGR video, I still have two possibilities.
Call me lazy, but I prefer to eliminate the possible easy fixes before I tackle the less easy! TBH, this EGR valve possibility is a nice little spanner in the works.
I still agree with you that the coolant stat is more likely, but if it's the EGR and a spray can will fix it... I'll certainly let you know!
Old 02-10-2024, 02:41 AM   #7
NZ XR6
My MB does something similar, it's always taken a while to warm up and the temperature drops on a long downhill. It's been like this for a long time, but never goes above the halfway mark on the temp gauge. If it stays low or overheats, I'll investigate further.
Interesting to know it has a heat exchanger to cool the oil, which may partly explain why it has always been slow to warm up.
Sent from my SM-S906E using Tapatalk
Old 02-10-2024, 05:44 AM   #8
AlCan
Crazy Mondeo Fan
Originally Posted by NZ XR6 View Post
My MB does something similar, it's always taken a while to warm up and the temperature drops on a long downhill. It's been like this for a long time, but never goes above the halfway mark on the temp gauge. If it stays low or overheats, I'll investigate further.Interesting to know it has a heat exchanger to cool the oil, which may partly explain why it has always been slow to warm up.
Hi Fellow Kiwi,
Your one sounds like it's normal, same as my 2011 MC. I agree, the HE probably does / must increase warmup time, but running warm oil thereafter must improve overall fuel economy (and engine life?) I'm very impressed with these engines and they have really changed my opinion of French engineers. (Pity about the P/S transmissions though! Are they US-designed?)
The 2013 has this varying low temperature problem, and I can't wait to see if the EGR has something to do with it - but it's down in the SI.
Regarding the Heat Exchanger, does the MB have a DW10B engine? I don't know very much about those, and I'm not sure if it has an Oil Cooler / Heat Exchanger (I think they maybe all do), but they might also have that Oil Temp Thermostat. Or they stopped using those after 2008? Don't know, but you can find them all over the place, just Google Images for 'Mondeo 1128018'. The MC/DW10C engine also seems to have a small (oil?) cooler located on the underside of the driver's (Ok, right-)side floorpan but I haven't done any investigation of that as yet.
These cars are nothing if not interesting!
Old 02-10-2024, 06:28 AM   #9
AlCan
Crazy Mondeo Fan
FWIW...
The MPS6/DCT Power Shift Transmissions were made by Getrag of Germany.
Getrag had three JV companies, one with Ford, also in Germany (Cologne).
In 2015, Getrag was acquired by the US company Magna Powertrain. Not sure what then became of the Ford-Getrag JV.
Old 02-10-2024, 09:55 AM   #10
NZ XR6
Originally Posted by AlCan View Post
Hi Fellow Kiwi,
When it was new, the temperature stayed constant once it finally warmed up, which could take 10 minutes on a cold morning.
I'm not sure about the engine type in mine. Ford changed to a Euro 5 engine late 2010, and I understand there are some MB's with the later engine and Powershift box. Very pleased I didn't get one of those!
Old 02-10-2024, 11:04 AM   #11
AlCan
Crazy Mondeo Fan
Which g/box do you have?
The DW10C engine has the oil filler in the near left corner of the engine cover (viewed from the radiator), and the dipstick ~100mm away at about 1:30 from there. And the soft rubbery cover over the injectors.
I'm guessing that the completely stable temp when new was because it was still running in, so more frictional heating. On long downhills, fuel injection shuts off completely (per the Economy readout in the Amber digital display), and there's not much else to generate heat. More noticeable in cold conditions.
Old 03-10-2024, 07:17 AM   #12
Peter B - CV8
A faulty coolant thermostat(ie stuck open) will result in a longer engine warmup & running too cool when cruising, especially on downhill coasting.
Old 03-10-2024, 09:43 AM   #13
AlCan
Crazy Mondeo Fan
Hi Peter,
Yes, got it, thanks!
Please forgive me - I'm not ignoring your good advice! I was a 'problem' child and apparently still am!
I agree completely that a faulty thermostat is very likely and behaves exactly as described, to the point that I already bought one. Just haven't installed it yet...
Now learning that these cars are slippery critters that love to make mischief for us hapless owners. (I have another thread to start soonish which may show that very clearly.)
As aussiblue has tossed in another possibility (EGR valve issue), I want to check that out first since it's a 2 minute job. If I have an EGR valve that's currently at the rumoured "sweet spot", I think it's worth investigating. It makes no obvious sense and may be a complete wild goose chase but I'm up for it.
Just can't get my hands on the car for another couple of weeks.
Old 04-10-2024, 07:01 AM   #14
Peter B - CV8
No worries mate - all good :-)
Hope the fix is a simple & cheap one. Keep us posted.
Old 05-10-2024, 04:53 AM   #15
NZ XR6
It's the 6 speed auto. From your description, the car has the DW10C. It goes well and gets around 6 l/100 km on long trips. But with the current RUC and diesel pricing, it's probably more expensive to run than a petrol car.
