09-12-2006, 02:19 PM | #1 | ||
my ride
ok any one no where i could buy a propper cold air intake for an eb i looked every where no one has them anymore. Or make my own, any ideas, or another model that fits
09-12-2006, 02:33 PM | #2 | ||
ORSM FORD CRUSIERS
Make Your Own.
BLUEPOWER RACING DEVELOPMENTS Strive for perfection in everything we do. Take the best that exists and make it better. When it does not exist, design it. Accept nothing nearly right or good enough. -[BLKPHN] (VIC) PLATES FOR SALE $495.00-
09-12-2006, 03:32 PM | #3 | ||
i agree with ebmanul, make your own...im finishing mine this weekend
09-12-2006, 08:11 PM | #4 | ||
my ride
How Did U Do It
09-12-2006, 09:12 PM | #5 | ||
I'm making sort of like a dual pod kinda setup. i have a T shaped piece of hosing and am sticking my pod onto one end and an old foam sock like on the old school pods onto the other side... and then making the whole corner where the filter goes into one big box.
09-12-2006, 10:51 PM | #6 | ||
ORSM Ford Cruisers
hey obriza it would be great to see some pics
ORSM Ford Cruisers < click here
1993 EB2 Gli---->Build Thread 2008 FG XR8 SEDAN 300RWKW N/A 2008 FG XR6 TURBO-UTE>>> SOLD 2002 AU3 XLS UTE>>>SOLD |
09-12-2006, 11:45 PM | #7 | ||
my ride
hey obriza where u from would not mind checking ur set up out one time, there are so many diff set ups
09-12-2006, 11:53 PM | #8 | ||
Location: Under the bonnet, trying to keep as clean as above!
here's a few picks of mine:
i got that from A1 Exhausts Caboolture in QLD, OED 666 put me onto it as he has one and has all the info about them, so just ask him and he should be able to give you the phone number and all other info. and that is my little invention! |
18-12-2006, 07:08 PM | #9 | ||
normality is boring
hey do u want a better version of the stock intake or are u lookinging into doing some body mods to get a proper cold air induction
18-12-2006, 07:16 PM | #10 | ||
ORSM FORD CRUSIERS
make one like this worked a treat b4 my car was forced. had the pod in the gard sucking sweet cold air. be sure to clean it regulaly.
18-12-2006, 07:27 PM | #11 | ||
please be aware of 1) the legalities of pod set ups and 2) pods in guards and forced intakes in bumpers and the like can pick up water and oh my god if that happens you engine is completely destroyed
18-12-2006, 07:31 PM | #12 | |||
ORSM FORD CRUSIERS
well i had mine on there for at least 6moths of melbourne weather, and well my car was fine, they acctually make water injection kit for car's, and as for the the legalitys, it is quite legal to cut a hole there providing you get it engineered as all modifications needs to be!
18-12-2006, 07:45 PM | #13 | ||
V8 Ute V8 Boat
i cant remember where iv seen it but a car just had a pod shoved over the intake body in a EB or ED log manifold and it would have great flow from the fan and cool air as the radiator is there and that gets lots of air
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
18-12-2006, 07:51 PM | #14 | |||
ORSM FORD CRUSIERS
hmm nop that side is covered by the fan shroud, and gets very little air flow and it will be hot air coming from the radiator.also a longer intake allows more tourque to be produced the reason why the made the BBM and the EB Gt's have that banana looking tube sticking out of the intake pipe. sorry i don't mean to be shutting everyone down! just letting you know some info.
18-12-2006, 08:07 PM | #15 | ||
Aspiring mr efxr
ebmanul isnt it illegal to cut through the chassis of the car? i was looking at cutting where u have but was told it will be unroadworthy....
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
18-12-2006, 08:11 PM | #16 | |||
ORSM FORD CRUSIERS
i didn't cut through the chassis, the chassis is a step down closer to the engine. the hole i cut can be engineered, however it isn't but i did findout if it is leagal vis a local vicroads aproved engineer.
18-12-2006, 08:17 PM | #17 | ||
Aspiring mr efxr
so i could cut my 3" hole there and get it engineered and be roadworthy in vic and nsw?
18-12-2006, 08:48 PM | #18 | ||
ORSM FORD CRUSIERS
as i said the engineeer i spoke to says it is ok but, speak to an engineer in you area chause it is up to his descresion to decide.
18-12-2006, 10:04 PM | #19 | ||
Aspiring mr efxr
sweet thanks mate.
x-chaser - modify, modify, modify!
18-12-2006, 11:04 PM | #20 | ||
this is no good for the cars fitted with ABS..
This is what i have, and EB Pete
Powered by Rollin Motorsport Turbo Barra ED 4L
18-12-2006, 11:11 PM | #21 | ||
Aspiring mr efxr
its a GLI so no problem there
18-12-2006, 11:46 PM | #22 | ||
this is what mine and Ebmanul's one looks like under the bar, mine has been on for around a yeh and it's fine in the wet weather, plus i use a k&n re-charge kit on it once a month so it stays healthy.
IMG]http://i147.photobucket.com/albums/r297/luke089/SP_A0327.jpg[/IMG] thanks Luke |
18-12-2006, 11:48 PM | #23 | ||
sorry hear it is
19-12-2006, 12:32 AM | #24 | ||
ORSM Ford Cruisers
hey OED666 how did u make that . did you modify another one ect. and does that fit pod or pannel filter
19-12-2006, 10:26 AM | #25 | ||
NC Fairlane Ghia
Hw abt something like mine
theres an pod in the box with the top open inside
Curent Rides: -NC Fairlane Ghia 3.9L -XC RallyPack Ute 5.8L -AU Falcon Wagon 4.0L Still Stock -80 Series LandCruiser 4.5 LPG |
19-12-2006, 11:14 AM | #26 | |||
19-12-2006, 11:20 AM | #27 | ||
ORSM FORD CRUSIERS
or you could do this and be done with cold air intakes,
22-12-2006, 12:41 AM | #28 | ||
|AFordEd|
Hey, um with the podfilter, how is it beinfical if you have it in a box, rather than just leave it stock? if you were to put a 3" hole in the car n have it underneath i could understand, but what other ways are there of doing it?
22-12-2006, 11:44 AM | #29 | |||
xc - my other love
cheater
Power = Money
How fa$t you wanna go?? apparently pretty fast - 400rwkw BF xr6t! FG F6 bottom end - GTX3582 - Nizpro 4" exhaust - Nizpro cooler - plazmaman intake - piping - plenum - batt relocation - injectors - surge &044 pump - valve work & valve springs - XCAL |
22-12-2006, 01:44 PM | #30 | ||
ORSM FORD CRUSIERS
ok so maybe it is cheating, but its more fun!
