Old 21-02-2013, 06:01 PM   #1
Lajon
Default PCV Valve
G'day is this the correct PCV valve for the series 1 Au Lane?
http://www.supercheapauto.com.au/onl...pid=7531#Cross
I found the manufacturer's website and it has the PCV-008 listed as the compatible unit for the AU but it completely different to what is in the car as it has 2 plugs for hoses
Lajon is offline   Reply With Quote Multi-Quote with this Post
Old 21-02-2013, 09:10 PM   #2
GK
Walking with God
GK's Avatar
Default Re: PCV Valve
I may be missing something in that pic, but the silver bit goes into the rubber grommet/opening in the crankcase and the black bit on top connects to the hose feeding back into the intake.
BTW, that's a metal unit. You need a plastic unit. The metal units have been found by a few here to result in higher oil consumption, as the spring inside the valve is lighter than stock.
Cheers,
GK
Now gone!
On LPG
Want a Full Life? John 10:10
Old 23-02-2013, 02:06 PM   #3
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
GK is correct
UK
Old 23-02-2013, 03:04 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
GK is correct
MH
Old 23-02-2013, 04:12 PM   #5
Papa Smurf
Papa Smurf's Avatar
Just remember if you buy the correct plastic one you will need to also to get the black angle piece that goes on top.
Papa Smurf is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 04:14 PM   #6
Evgeni
Auto Nerd
Evgeni's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: In recognition of the many hours spent scanning information for the benefit of AFF members.
Yep, those metal PCV's sucked about 100mls of oil out of my motor every 1000km's
Evgeni is offline   Reply With Quote Multi-Quote with this Post
Old 23-02-2013, 06:40 PM   #7
GasoLane
Former BTIKD
GasoLane's Avatar
Could I suggest you go to a proper spare parts place, and not the K-Mart for Cars.
Old 24-02-2013, 03:04 PM   #8
GK
Walking with God
GK's Avatar
This is true.
When I first bought one from Ford, many moons ago, the black piece was included in the $10 or so price.
Last year IIRC, I went to Ford to get a newie, which was $15 or so, plus another $12 or so for the black piece.
Didn't buy it!
GK
Now gone!
On LPG
Old 24-02-2013, 03:59 PM   #9
Uncle_Ken
Uncle_Ken's Avatar
Maybe its Windows 8 complient
UK
Old 26-02-2013, 03:33 PM   #10
mik
mik's Avatar
i bought a new steel one myself thinking it would be better after the old 10 year old plastic one carked it, i ended up going back to the plastic.
Old 22-06-2022, 04:23 AM   #11
asimplelife
mechanical novice hopeful
Wish I had read this thread BEFORE I just put in a metal PCV valve, thinking it MUST be better than the faulty plastic one I had :(
Also wanted to note, the new PCV valve has immediately fixed my running rich problem on an AU3 VCT motor I had recently installed.
I also suspect it will resolve another nagging problem, where sometimes, on a cold morning, if I had parked uphill overnight, I leave a trail of oily smoke behind me from the exhaust. As if the rings were badly worn. But the compression is very good. And it only happens sometimes under the noted conditions.
PS - yes...I know it is a thread mine
But adding the little bit of useful knowledge I accumulate to existing threads, seems to be the best way I can compliment this excellent body of knowledge, which I call on almost daily (apologies again for not contributing much...once I finally get back to just 2x AU falcons...I will hopefully have some free time to do so more)
asimplelife is offline   Reply With Quote Multi-Quote with this Post
Old 03-07-2022, 11:59 AM   #12
Uncle_Ken
Uncle_Ken's Avatar
always welcome
