Old 30-05-2015, 10:39 PM   #1
Angelmon
Default having problems with idle with video
Hi every one i need some help with my falcon
Im getting a really rough idle i stumbled upon this post
How U going? I'm an ex ford mechanic and have worked on ****loads of AUs with rough idle.. Here is a typical fix au idle list( need access to NGS or WDS diagnostic systems) Check IAC % is 30-35%..base idle screw is adj to obtain IAC %. Check and adjust TPS to voltage reading of 0.7v. check pcm for updates.
now my IAC% goes down to 0% and when i disconect the IAC nothing changes is this normal? and to adjust it do u use the black knob or the screw on the throttle stop?
here is a youtube vid i took what do you guys think
https://www.youtube.com/watch?v=5xVlXxl9sLw
Angelmon is offline   Reply With Quote Multi-Quote with this Post
Old 30-05-2015, 11:57 PM   #2
baboon
Contributor: For members who make a contribution worthy of recognition. - Issue reason: went to the trouble of posting up some great Vids of the AFF drag meet
Default Re: having problems with idle with video
From the video, your car matches up with the post. IAC% 30-35% and TPS 0.7v.
baboon is offline   Reply With Quote Multi-Quote with this Post
Old 02-06-2015, 10:49 AM   #3
Angelmon
that is correct but it drops down to 0% is that normal ?
Old 02-06-2015, 01:21 PM   #4
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
is it petrol or gas?
i know the gas cars would do this when they'd get a leaky diaphragm. stick your hand down the cold air intake (before the airbox) and see if it improves. My memory it was getting too much air in the mix or something like that?
Old 02-06-2015, 06:43 PM   #5
baboon
PCV valve broken faulty?
Old 06-06-2015, 02:40 PM   #6
Angelmon
Its on petrol only, dont know if the pcv is faulty does anyone know how to test it
