likes falcon's
from ea series 2 to an ed/ef style one and now it doesnt want to go into 4th gear :S
anyone know why?
www.carhubsales.com.au |
#2 | |||
I think the voltage values are slightly different between the two.
likes falcon's
only .3 difference
#4 | |||
AFF's 1st DM.......
Did u set em both up for the same values?
FORD GIVING POWER TO THE PEOPLE Alloy headed 347ci EDXR8 13.21 @107.7mph Quote:
likes falcon's
how do i do that :S lol
there was 2 bodgy old school ea tps's i replaced it with a late ed early ef onwards one ea2ba (jason) reckons all i had to do was chop and join the 2 tps's to the one plug
#6 | |||
AFF's 1st DM.......
lol.
both tps switches have to read the same value afaik, Ill check out the God Book when i get home mate...
likes falcon's
all i did was snip the 2 ea tps's loom plugs, and connected them together
green & green to new tps orange & orange to new tps black & black to new tps
#8 | |||
There is your problem. You had one TPS for the trans and one for the ECU. Wiring them both together can stuff the signals up. Now your trans computer isnt happy with the signal its getting.
likes falcon's
thats what jason said he did lol
what can i do to fix it?
I build your wish list...
try unpluging just 1 of them go 4 a drive and see if it goes back to normal? Maybe jason changed the e.c.u. as well ??
#11 | |||
Put the EA TPS' back in
#12 | ||
likes falcon's
i snipped the loom of them :( lol
pardone my ignorance
but what's a TPS ?lol |
#14 | ||
Throttle Position Sensor
#15 | ||
is it located on the box near the inhibater switch??
#16 | |||
Its on the side of the throttle body
#17 | ||
yep im following thanks for the info
#18 | ||
Last warning
i'm fairly sure InitialD and Sundeep both swapped to the single TPS, had issues so had to swap back.
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
#19 | |||
yeah, there are issues with the internal bias resistors in the ECU and TCU messing with the signal. Unless your changing throttle body or ECU I cant see any reason why you would change the setup.
#20 | ||
windsor user
there is absolutley no benifit or gain to be had by changing the TPS.. why would ya bother?
just put the normal EA ones back in |
#21 | ||
likes falcon's
wayne, there is a benifet, its the only one that would fit on the gasresearch throttle body.
#22 | ||
![]() Join Date: Aug 2005
Both TPS switches are the same except for one has a straight through hole. At work the Mechs will use one for the other if they suspect there is a problem with the Engine one of the Gearbox one?
#23 | |||
windsor user
#24 | |||
Low and Loud
JUST FOR EVERYONE SO THIS IS KNOWN THROUGHOUT THE LAND OF FORD! You can't fit a EB2/ED/EF/EL single TPS to a EA series 2 or EB series 1 Throttle body. Even though it will screw on and you can bridge the wires, the TCU (Transmission Control Unit) will get confused and make your auto go all crazy as the ECU Throttlebody signal and transmission kickdown signals get messed up. Soon as the DUAL TPS's were refitted my auto worked correctly and stopped chewing through petrol like a 347 V8. Now in your case Niko, isnt your car manual? so there for you would only need to connect the ECU TPS and not bother with the blue TPS wiring/plug that is the auto? or is this for a different car. IF for a different car, you could just pull the Throttlebody apart and change the main shaft in the throttlebody to the EA2/EB1 style with larger shaft for the TPS's? or just get the correct Throttle body Now sundeep and I have BOTH told jason (EA2BA) that his way cause's issues but Im still unsure if he ever listened to me to change it back, but doesnt bother me, just means im faster then him ![]()
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
#25 | ||
likes falcon's
im running an eb2 non smartlock ecu in it, is there anyway to get around this problem with that ecu in there?
#26 | |||
Low and Loud
![]() ![]() ![]() ![]() ![]() EA's have a external trans controller. and also how the heck does the car run? I tried a Eb2 non smartlock ecu into a EA once and it barely ran
#27 | ||
likes falcon's
it runs awesome. lol
thats why its still in there
#28 | |||
Low and Loud
#29 | ||
likes falcon's
my mums ea, the clean silver one
i also mentioned in the intitial post that it wont go into 4th gear. ![]()
#30 | |||
Low and Loud
A) rewire the car to EB2/ED (little hasty for just a TPS) B) resolder on the EA dual tps style or replace the MPFI loom with a new one and install the TPS's again
