29-04-2012, 11:01 AM | #1 | ||
Define definitive
Hey everyone, last night I took my mate home and when he got out of my xr6 the door wouldn't shut properly. Keeped just opening back up. After a few times it closed. It's only the pasenger side front thats doing it. What could it be? Haven't had time to look at it yet
BF F6 TYPHOON in NEO #718 ~ 356rwkw : BF XR6 TURBO in SILHOUETTE |
29-04-2012, 11:09 AM | #2 | ||
rexnet
Are the screws that hold the accutator loose? I've found mine loosen sometimes and this happens
29-04-2012, 11:39 AM | #3 | ||
Former BTIKD
Wont shut or wont lock?
29-04-2012, 04:10 PM | #4 | |||
Define definitive
29-04-2012, 04:31 PM | #5 | ||
Former BTIKD
Must be worn either in the door or the striker plate.
If it was me I'd have a talk to a friendly panelbeater and ask why it wont close and how much to fix it.
29-04-2012, 06:34 PM | #6 | ||
mine did that on the rear driver side, latch would stay in the open position after lifting the handle.
a good dose of lithium grease on the locking mechanism fixed it |
30-04-2012, 10:27 PM | #7 | ||
Define definitive
Thanks guys, I'll give the grease a go a check the screws and go from there. Hasn't done it since then
01-05-2012, 01:06 AM | #8 | ||
Happened to me once, turned out the rubber door seal had come out and was making it bounce back open.
01-05-2012, 10:18 AM | #9 | |||
http://i56.tinypic.com/23hlk6p.jpg |
01-05-2012, 11:05 AM | #10 | ||
well I just went out and checked my rear passengers door as it wouldnt close properly sometimes either, and sure enough the bottom of the door seal had come ajar, as soon as I put it back on VIOLA!!!
02-05-2012, 03:07 PM | #11 | |||
Former BTIKD
Some people consider this as not shutting properly.
25-05-2012, 02:41 PM | #12 | ||
yeah sim prob here but my door just flys open ,i had the whole unit out and the only time it close properly is when i pull the central locking arm down it will close but if i dont it wont close .it has something to do with that arm off the locking unit it self i think
does anyone have passenger side door latch the one with all the arms off it inside the door,i may need cheers |
