Old 07-07-2017, 10:27 PM   #1
IH8HSV
XR6T 400kw(well one day!)
IH8HSV's Avatar
Default Fault codes causing limp mode
Hi all,
My mums car is going into limp mode.
We took it to super cheap and got the following codes:
P1270 ( engine speed rev / limiter reached )
P2110 ( throttle actuator control fault ( TAC ))
P1507 ( idle air control fault ( IAC ))
Can someone please shed some light on what could be wrong?
Im trying to find a link between the throttle actuator and the idle air control.
Thanks in advance.
If it Vibrates, rattles, squeaks or knocks - then it must be a Territory
IH8HSV is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2017, 10:33 PM   #2
IH8HSV
IH8HSV's Avatar
Default Re: Fault codes causing limp mode
Here is the actual super cheap sheet.
Obviously the first 3 highlighted lines are my concern.
Thanks.
https://ibb.co/btgScv
Old 08-07-2017, 12:15 AM   #3
lucas2
lucas2's Avatar
What's the battery like? That can cause issues and may be worth looking into before you go replacing lots of parts.
BF MKII XR6 CONQUER (SOLD)
FG XR6T SILHOUETTE - 380rwkw
lucas2 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2017, 12:29 AM   #4
bawagon2012
Sounds like a Throttle position sensor (TPS) Fault, Or as lucas2 said the Battery.
bawagon2012 is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2017, 12:49 AM   #5
Hmm... Are you sure it's your mum's car?
Old 08-07-2017, 02:47 AM   #6
Those 3 codes with U prefix suggest either the scanner was not fully plugged into the diagnostic port (the most common cause), the scanner is faulty or the diagnostic port is faulty. As a first step you need to get it scanned again perhaps elsewhere and make sure the scanner plug is pushed into the diagnostic port as far as it will go.
Old 08-07-2017, 01:28 PM   #7
IH8HSV
IH8HSV's Avatar
It seems to shudder and feels like its going to stall but doesnt - mainly at low speed.
Then sometimes it will just lose power and stop. Once I restart it then its ok.
Anymore suggestions please?
Old 08-07-2017, 05:03 PM   #8
ratter
ratter's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Shares his in-depth tuning knowledge with the forum, very helpful. Contributor: For members who make a contribution worthy of recognition. - Issue reason: For his indepth tutorial on adding borders to photographs
I would be checking for vacuum leaks
Pit Lane Performance
20 Rosella St Frankston 03 9783 8122
Authorised Streetfighter, Pcmtec , SCT & HP Tuners Tuning Agent,
ratter is offline   Reply With Quote Multi-Quote with this Post
Old 08-07-2017, 05:37 PM   #9
It might also be that the ECU plugs have come loose; see http://www.fordmods.com/post1394839.html
Old 08-07-2017, 07:49 PM   #10
IH8HSV
IH8HSV's Avatar
OK Thanks.
Where are these plugs located?
Also whats the best way to test for vacuum leaks?
Thanks.
Old 08-07-2017, 07:54 PM   #11
If the inlet manifold is leaking it's usually at the bottom of number 1 or 6 inlet manifolds where they bolt onto the head. The best way to find it is too put a length (1/2 a metre) of windscreen sized tubing in one ear while moving the other end around under the manifold listening for a telltale sucking noise; do this with engine idling both when the engine is a hot and when it is cold as the change in head and manifold temperatures can sometimes temporarily close up any gap between the head and the manifold.
Old 08-07-2017, 08:07 PM   #12
The Electronic Control Unit (ECU) or Power Control Module (PCM) is in the engine bay on the passenger's side near the windscreen it's the aluminium box like this: http://www.ebay.com.au/itm/FORD-FALC...MAAOSwSlBYzI-N and this. As you can see the plugs are underneath on the engine side. Disconnect the battery and ensure the ignition is off and the key removed before playing with the plugs or unbolting the ECU/ PCM otherwise you risk damaging it.
Old 08-07-2017, 08:39 PM   #13
IH8HSV
IH8HSV's Avatar
Thanks Aussieblue.
I was reading that there is a Technical service bullitin for BF's stalling. TSB 20/05.
Something to do with cleaning the throttle body. Is there anyway I can read this?
Thanks.
Old 08-07-2017, 08:41 PM   #14
IH8HSV
IH8HSV's Avatar
Also...
Can I clean the TPS?
If I do is there a procedure to ''re-learn' it when i put it back together?
Thanks
Old 09-07-2017, 08:56 PM   #15
IH8HSV
IH8HSV's Avatar
The battery is 3 years old. Sometimes I have to jump start it.
Are you saying that this can cause an intermittant problem?
Thanks.
Old 09-07-2017, 09:11 PM   #16
Are you saying that this can cause an intermittent problem?
They don't last any longer than that and if you have to sometimes jump start it, it's time for a new one. And yes a below par battery will cause both fault codes and running problems. The electronics, including the PCM, need a specified minimum voltage (can't find it at the moment but something like 9.6 volts I think).
Old 09-07-2017, 09:30 PM   #17
IH8HSV
IH8HSV's Avatar
Hmmm..
OK. That is interesting.
Maybe Ill start with that.
While im at it - where is the Idle control unit? I looked on top of throttle body but wasnt to sure which it was.
Was told to clean this too.
Thanks.
Old 10-07-2017, 10:46 AM   #18
ratter
ratter's Avatar
your throttle body is your idle control unit
Old 10-07-2017, 06:13 PM   #19
IH8HSV
IH8HSV's Avatar
Ok,
Thanks for all that.
Im going to replace the battery, clean the throttle body and replace the TPS.
Hopefully that will cure it.
Thanks
Old 29-09-2019, 12:57 PM   #20
rxrk
According to the owners manual.
If your battery is 9 volts or below it will send the car into limp mode.
rxrk is offline   Reply With Quote Multi-Quote with this Post
Old 29-09-2019, 02:11 PM   #21
It might also be a failed throttle body as it is not uncommon. See https://fordforums.com.au/showthread.php?t=11479350
Old 28-02-2021, 01:04 PM   #22
3phase
Did you ever get to the bottom of this? my car is doing exactly the same thing.
2003 BA falcon
3phase is offline   Reply With Quote Multi-Quote with this Post
Old 01-03-2023, 01:12 PM   #23
Fairlane420
Hi mate did you fix this issue?
Fairlane420 is offline   Reply With Quote Multi-Quote with this Post
Old 02-03-2023, 11:09 AM   #24
3phase
Yes, it was a faulty inlet gasket with my one.
Replaced it and she ran like a dream.
