Old 25-07-2021, 10:38 PM   #1
kiwimagic
kiwimagic's Avatar
Default 1991 Ford Capri Speaker wire
Hi All
My 1991 Ford Capri arrived without a Audio system.
I have recently purchased one to fit in the car.
BUT previous owner or owners have cut the original wires and connected another plug.
So can any one tell me what colour wires positive and negative connect to which speaker.
cheers
kiwimagic.
1990 F150 351 W. (for Sale)
1991 SAII Verde Capri Convertible DOHC (sold)
1994 SE XR2 Turbo Capri Convertible DOHC (Sold)
2010 Ford Fiesta (wife's Car)
2017 Blue Sky Monterey caravan.
2017 Ford Ranger XLT.
kiwimagic is offline   Reply With Quote Multi-Quote with this Post
Old 26-07-2021, 03:06 PM   #2
russellw
russellw's Avatar
Default Re: 1991 Ford Capri Speaker wire
I'll add it to the Tech Portal doc shortly but the speakers are blue and blue with a white stripe - the striped ones being the negative.
Old 29-07-2021, 09:39 AM   #3
kiwimagic
kiwimagic's Avatar
Hi russellw
I hooked up my Iphone using a jack and two wires.
front RHS; Blue with Red Stripe
Blue with Yellow Stripe
Rear RHS: Same as Front RHS
Front LHS: Blue
Blue with White Stripe.
Rear LHS: Same as Front LHS
There are three wires left:
1/. Red with Black Stripe,
Using a multi meter this is earthed.
2/. Black with White Stripe.
As this is the only one left I assume this is power from battery.
I can not check this at the moment as Im in the middle of fitting a push button start/stop unit and have the ignition wires disconnected.
3/. Black with Yellow Stripe.
Old 29-07-2021, 10:56 PM   #4
foxtrot3
foxtrot3's Avatar
Hi. Wait till you get the battery hooked up and the ignition switch setup sorted out and check those last 3 wires with a test light. One of them will be constant 12 volts for memory, another will be accessory 12 volts so the radio turns on and off with the ignition switch and one will be dial lights. The earth would have been a seperate black wire bolted to the dash framework. Cheers MD
HI
I'M MICHAEL
foxtrot3 is online now   Reply With Quote Multi-Quote with this Post
Old 31-07-2021, 06:13 PM   #5
kiwimagic
kiwimagic's Avatar
Ok
Wiring all sorted.
Red with black trace
Lights
Black with yellow trace
Hot at all times.
Black with white trace
Hot in Acc and Run.
