Old 15-07-2007, 08:00 AM   #1
ed ant
ed ant's Avatar
Default alternater problems
hi guys my alternater has been playing up i put new belts on and it is screaming it head off and the gauge is flicking but then it comes good as soon as you idle the car it starts again is it time for a new one
black ed lowerd king springs 16" mags pioneer sound system. :
ed ant is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2007, 10:16 AM   #2
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Screaming its head off as in the belt is screeching/squealing? Tighten your alternator belt a lot more. They have to be b@$tard tight so their quiet.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 15-07-2007, 10:24 AM   #3
ed ant
ed ant's Avatar
ok ill try that thanks
Old 15-07-2007, 10:38 AM   #4
DEVL-XR
EBII XR6
DEVL-XR's Avatar
You'll see on the alternator a larger nut and a smaller nut. You can lightly back off the tension on the larger nut and use a ring spanner for the smaller nut to tighten. There teeth on the inside of the bracket that the alternator will climb when you tighten. If you get the tension right with the larger nut the alternator wont move when you tighten the smaller nut. Once its tight enough, tighten the larger nut.
Hope that makes some kind of sense.
DEVLXR
