Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link |
15-06-2021, 01:31 PM | #1 | |||
Race Brakes Sydney
So I have a series of questions:[LIST=1][*]Will the bigger Rotors and Calipers fit under my Factory Turbo Ghia rims. (18", standard 7.5" 36.5mm offset.) I know that 14" rotors will fit 18" rims, but I don't know if 15" rotors will fit, nor what offset is needed for the Brembo Calipers. - No and if you go larger than 14" rotors custom brackets will need to be made and clearance depends on the wheels you get [*]Will the Brembo Calipers bolt straight on? - No Or do I need dogbones? And if so what are they made from? You will need brackets and they will be either steel or alloy I have seen some awfully flimsy crap sold as "Brembo Fitting Kits" and I certainly wouldn't trust my brakes to them. - I wouldn't either [*]Do I need to change the Master Cylinder, ABS Module, EBD pump, etc? We haven't had too [*]Is any reprogramming of the TC or DCS required? Not that we have seen customers need to do [*]What is the advantage of cross-drilled, slotted, and/or dimpled rotors? Looks but mainly dissipate heat and water and cooling along with grip..
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop Street to track is what we expertise in Phone 02 9609 1101 sales@racebrakessydney.com.au www.racebrakessydney.com.au |
