Old 06-08-2018, 04:59 AM   #1
happy1
Default UK university may have solved Diesel pollution problem
Loughborough University (UK) claims it has made a new system for reducing, and possibly eliminating, dangerous NOx emissions from diesel engines.
Their ACCT system improves existing SCR / Adblue based systems to also work with a cold engine.
http://autoweek.com/article/diesel/d...x-its-possible
http://www.lboro.ac.uk/enterprise/acct/
Cheers,
happy1 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2018, 12:00 PM   #2
bangm001
Mopar! But Own F6's..
Default Re: UK university may have solved Diesel pollution problem
All fine until people rip it off anywhere to make more power.. So many diesel vehicles on the road with no particulate filters its not funny..
F6 TYPHOON
FPV 335 GT
bangm001 is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2018, 04:21 PM   #3
smoo
smoo's Avatar
Who cares.
What do you think happens to all the crap in the filter when it does a re gen... have you being inside a shed or garage while a re gen is going on?
smoo is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2018, 06:57 PM   #4
RANGEREST
Same ****-Different Day
RANGEREST's Avatar
Originally Posted by smoo View Post
Who cares.
SCR and DPF are two different things, buy yes when a DPF does a re gen indoors gtfo.
Bax.
Current Vehicles
RA Wildtrak V6,
UA2 Everest Trend 2.0lt
RANGEREST is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2018, 08:38 PM   #5
simon varley
unfortunately I think the damage has been done at least for passenger car diesel power. can't see it lasting into st7. public pressure has turned against small diesels in their major Eu markets.
simon varley is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2018, 09:31 PM   #6
Sprintey
Sprintey's Avatar
Seek and you shall find:
https://www.youtube.com/watch?v=7qIh5PqeVqM
Here's some indoor regen. So these particles are the larger, more easily trapped ones being burned off. And, if they are burned off later (in someone's shed/lungs) does that mean that there's really no point to the things as the particulates are going into the atmosphere eventually anyway?
I6 + AWD
Sprintey is offline   Reply With Quote Multi-Quote with this Post
Old 06-08-2018, 10:10 PM   #7
happy1
If SCR is getting so much better with ACCT, then there would be less deposits, less clogging up, and so on.
Diesels produce less CO2 per km than petrol engines which is needed, but the problem is NOX and particle removal systems such as SCR not working too well.
Old 06-08-2018, 10:55 PM   #8
Sprintey
Sprintey's Avatar
Have spent a quiet Monday evening learning a bit more... it appears Toyota were in the news in March with their DPFs on the 2.8
Any mech engineers or mechanics here? A Cadogan youtube comment suggested using air injection in the motor itself to clean the emissions - would this help? & also air injectors in the DPFs
I6 + AWD
Old 07-08-2018, 10:44 AM   #9
happy1
This page describes the current SCR:
https://www.dieselforum.org/about-cl...el/what-is-scr
I'm not sure if an engine with SCR still uses recirculation of exhaust (EGR)?
Cheers,
