Old 11-10-2012, 09:50 PM   #121
gh172
Default Re: Quick question re: DRL's
Had the DRL's installed today, love them!
Drives: MY11 MC Ford Mondeo Zetec TDCI
Daily: 2008 VW Golf GTI
gh172 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2012, 10:43 PM   #122
mas89
mas89's Avatar
Just added some rear drl using the rear fog lights cut down to 3.5-4 volts using an old phone charger..than turn off when park lights are turn on..
Fords Forever
mas89 is offline   Reply With Quote Multi-Quote with this Post
Old 16-12-2012, 11:10 PM   #123
Smoke Pursuit
Illegal.... Just be careful using them in clear weather the police hate them.
Smoke Pursuit is online now   Reply With Quote Multi-Quote with this Post
Old 17-12-2012, 10:13 AM   #124
MAD
Petro-sexual
MAD's Avatar
I hate them too!!
The only thing worse than fog lights, is the rear fog light.
EL Fairmont Ghia - Manual - Supercharged
- The Story
MAD is offline   Reply With Quote Multi-Quote with this Post
Old 17-12-2012, 03:16 PM   #125
mas89
mas89's Avatar
I hate rear fog light aswell...what I have done is made them run on lower power which mades it 6 w brightness not 21w ..
Fords Forever
Old 17-11-2013, 12:31 PM   #126
Greane01
Greane01's Avatar
So - trouble with the DRLs...
Two of the four LEDs on the driver side DRL keep switching off then on again with no apparent pattern... Anybody else have this problem, or anyone have a suggestion as to what may be causing this? They have been working fine since I put them on at least 12 months ago...!
Greane01 is offline   Reply With Quote Multi-Quote with this Post
Old 17-11-2013, 04:23 PM   #127
MAD
Petro-sexual
MAD's Avatar
Sounds like the LEDs have burned out. Probably not much chance for repair.
- The Story
Old 22-11-2013, 10:42 PM   #128
Greane01
Greane01's Avatar
I originally disagreed with your assessment, as the two troublesome LEDs were still working (albeit intermittently); however, they were definitely in their death throes and are now completely dead, leaving two functioning LEDs in the driver side DRL.
Now, do I fork out more money (considering they are only 12 months old) for another pair and pull the car apart to fit them?!!!
Or, I guess I could damage two LEDs on the passenger side DRL to match?!
Old 23-11-2013, 02:19 AM   #129
ope126
ope126's Avatar
Time for some new ones!!!
Bar off again...
2016 (MY17) Ford Mondeo Titanium EcoBoost (Moondust Silver)...more power please!
ope126 is offline   Reply With Quote Multi-Quote with this Post
Old 28-11-2013, 06:18 PM   #130
mas89
mas89's Avatar
Or if you are game pull apart for a looksee a see if you fix the leds that have died. .
Fords Forever
Old 28-11-2013, 08:26 PM   #131
Greane01
Greane01's Avatar
I was going to replace the pair with new ones off eBay... But to be honest, it's low on my list of 'things to do'...
But yes, I would be keen to see if individual LEDs could be replaced...
Old 05-04-2015, 02:35 PM   #132
wazza675
New to the forum and just skimmed through this thread (while trying to ignore my daughters fighting in the background!!).
I'm about to pick up an MC Modeo LX (petrol) in dark micastone for the missus.
I'm currently running a series 1 VE Omega (with SS nose) and the Modeo will replace a T31 X-trail that was written off. Both cars have (or had in the X-Trail's case) Phillips LED DRL bars fitted for better daytime visibility. I'd now like to add DRLs to the Mondeo. Given the MC Mondeo has blanking pannels fitted where the DRLs fit on the higher optioned models, I assume they'll just clip in to the housing one the blanking is removed.
So now I have some questions:
1. Does the LX model have the required looms and plugs fitted as standard, and only require the lights? [As a side note, I know the VE Omega had the SS/SV6 loom in later production runs, and so the fog lights didn't require anything extra other than the lights, housing, and the pig-tail loom that stretched across the front bar].
2. Are the DRLs different between MA MB and MC models?
3. Are there equivalent quality DRL kits available that fit into the recess in the MC bar?
4. Are there any links for complete kits that would suit my application?
I don't really care whether the lights dim or switch off when the trigger lights (usually parkers) are activated. The Phillips units both came on with the ignition and remained on for about 10 seconds after the car was turned off. They also turned off completely when the trigger light was turned on.
Also, I guess the same questions apply for the fog lights.
Existing or required wiring?
Switch gear?
compatible models/variants?
Thanks in advance
Wazza
wazza675 is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2015, 04:32 PM   #133
Greane01
Greane01's Avatar
Quick response from the iPhone...
1. No looms or plugs or existing wiring. And no, they don't just clip on. You have to stick the DRL housing onto the bumper using a proper adhesive (I used sikaflex) and then the DRL clips in to that.
2. Yes. The MC, as you point out, has the blanking plates where the DRLs fit. Earlier bumpers are different.
3. And 4. Yes - eBay is your friend.
Sorry, can't help with the fog lights.
Old 18-07-2015, 08:31 PM   #134
Greane01
Greane01's Avatar
Update - two more LEDs have died; this time on the passenger side. Unfortunately they are the opposite two LEDs that died on the driver side, so they don't even match up now! All up, 50% of the LEDs have died in the three years since I bought them...
When it goes to one on each side, then I'll replace them...!
Old 09-12-2023, 05:25 PM   #135
goz007
Diesel Sniffer
goz007's Avatar
just wondering if anyone has turned off the DRL on an MD mondeo 2016+
goz007 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2023, 10:38 PM   #136
frankie86
Sprinting Everywhere!
frankie86's Avatar
I have, can be done via forscan
frankie86 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2023, 11:19 PM   #137
goz007
Diesel Sniffer
goz007's Avatar
Cheers thanks for the reply.....any chance u can list how u did it?
