Old 11-02-2007, 11:08 PM   #1
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
Default Base Idle Speed Eb Xr6
hey,
im wondering, how to reset the base idle speed on a EB XR6,
i have searched the forums and found nothing, i have since sold my car and given my workshop manual away so here is my next best option,
if you know let us know.
cheers
Tristan
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2007, 11:59 PM   #2
MADED-6
MADED.6
MADED-6's Avatar
its adjustable on the throttle body i dont no how to set it though.
cheers josh.
TUFAU-8
Get Stroked.
AU Stroked 5.6L GHIA
MADED-6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2007, 08:01 PM   #3
XR_Lightning
Riding The Lightning
XR_Lightning's Avatar
yeah there is an idle adjusting screw on the throttle body but you shouldnt really need to touch it, it should be set properly if it hasnt been screwed around before, here is what you should try first, you will need a clock/watch for this and car has to be running and at operating temperature and it is best to keep the handbrake on and your foot on the brake:
For 1 minute keep the car in neutral
For the second minute keep the car in drive
For the third minute put the car back into neutral with the a/c on
For the fourth minute put the car back into drive with the a/c still on
and then when the fourth minute finishes turn the ignition off, put car into park, turn a/c off, then start the car and it should be idling right
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA
XR_Lightning is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2007, 08:12 PM   #4
DEVL-XR
EBII XR6
DEVL-XR's Avatar
how about for a manual? my car idles very low.
DEVLXR
DEVL-XR is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2007, 08:36 PM   #5
eb2flyz
bettering 13.7
eb2flyz's Avatar
1) make sure the car is at operating temp
2) with engine off disconnect the ISC
3) start engine and turn base idle screw until rpm is correct (450-600rpm)
4) stop engine and reconnect the ISC
also it wouldn't hurt to clean your ISC
std stroke, alloy heads, comp cam, tfs manifold, 75mm t/b, 70mm maf, 30lb inj, adj fuel press reg, twEECer
FPV/Tickford Club of W.A
Performance is Electronic
BPT Motorsport
eb2flyz is offline   Reply With Quote Multi-Quote with this Post
Old 15-02-2007, 11:32 AM   #6
DEVL-XR
EBII XR6
DEVL-XR's Avatar
Sorry i think i've asked this question before but where is the ics, well i know its near the throttle body but i'm not sure which part it is. And how do you disconnect it? Pics would be a help!
DEVLXR
Old 15-02-2007, 01:25 PM   #7
nutcase
i think its that small round cylinder that sits on top of the throttle body. It has a wiring plug connected to it.
Someone before mentioned to adjust it to 450-600. Isnt that a little low? Should be around 750rpm in park and 550-600 in drive with foot on the brake
Old 15-02-2007, 02:49 PM   #8
DEVL-XR
EBII XR6
DEVL-XR's Avatar
my car is a manual btw and it normally idles at around the first mark of the rev gauge!
DEVLXR
Old 15-02-2007, 03:43 PM   #9
nutcase
A manual eseries !! lucky find there mate, every one i come across is a damned auto..
what was Ford thinking?
Old 15-02-2007, 03:48 PM   #10
DEVL-XR
EBII XR6
DEVL-XR's Avatar
modern way of life mate! Manuals have to be ordered now! I think i had more luck since its an xr6.
DEVLXR
